Lenovo  Keyboard Logo
d
debbie Posted on May 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My key board is not reading my numbers and on re start it keeps saying key stuck
Jeff x
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 14, 2014
Jeff x
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
1661
Points
5
Removing or deleting Trusted Devices from the Micosoft account fixed tge problem. There were incorrect and incompatible settings from a previous tablet that were disabling the keyboard. From a different computer, sign in to Microsoft account, Overview, Security, Trusted Devices, select the hotlink Remove all the Trusted Devices associated my account. Refresh Windows completely. All fixed.
Level 3:
  • Lenovo Master 19,187 Answers
Lenovo Master
Level 3:
Answers
19187
Questions
0
Helped
4346502
Points
82261
Turn it over and smack it on the back. See if the problem goes away. If you have spilled something on it that was sticky you can use armor all to clean it. Otherwise replace it. Generic keyboards are not expensive.
Hi, I have a Frigidaire dishwasher model number FGID2466QF7A. It’s displaying a “Er” code and nothing else is lit, unlike other posters here. I reset once using the Rinse Only and Start/Cancel buttons. The...
Frigidaire Dishwasher Error Code = ER
Error Problem / Condition = Membrane Switch Failure
Check / Repair / Solution = Main Control Board has detected a stuck key or a key pressed for more than one minute. Check connection from keypad to Main Control Board. If correct, replace keypad. If error still exist, replace Main Control Board.
https://removeandreplace.com/2016/02/18/frigidaire-dishwasher-error-codes-what-to-check-how-to-reset/
Have a kenmore c970-595084 and says F1 stove top still works oven does not. None of the electronic board works. Stove top is not part of the board as they have the historic knobs
Hey D, f1 can be one of three problems. A stuck key pad,test by pressing all the buttons to see if they all make noise, if one doesn't then that's the stuck one. A bad oven temperature sensor, if it's gone bad it will not send the proper temp reading to the control board. Or it could be a bad control board itself. If nothing is working/changing mode it's most likely the stuck keypad. If you're not comfortable working with electrical components I suggest calling your local repair company to check it out. Hope that helps.
1helpful
Intel DESKTOP BOARD D945GPB-Win XP Home Edition OS. All web searches keep crossref. all other boards D945G* or D945G**. No mention of D945GPB anywhere on net or Intel Site.
Boot up computer from being off and press pause key right top hand side of keyboard when the bios number comes up on the screen. Pause boot up and read the bios number that is displayed during the P.O.S.T sequence of your Bios start up.
Then try googling the Bios number to get the exact motherboard involved.
Good luck !
I have a gateway laptop running windows 8 and all of a sudden my number pad stopped working. I've searched and read till my eyes feel like they're going to fall out, help!!
Have you pressed/un-pressed the NUMLOCK key?
OR
You may have a stuck key somewhere on your 10-key numeric keyboard. Sometimes dirt (coffee, dust, soda) is blocking the contacts to the circuit board from the keyboard.
-GWOOD
Kitchenaid stuck key error
HAD THE same problem with a dishwasher,unplugging should clear errors. removed circuit board and re soldered connections and re installed,works fine now.probably a cold solder connection on board.
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
1helpful
Board number 200d2260g008 burnt where fuse is. Can I just replace fuse?
As a technician the fuse isn't even offer to us a part. I'm not saying its not possible, just that you'll need to be able to solder and read a schematic. but just keep in mind that if that fuse blew, how far up the line is that fuse from the initial power coming to the board and what else could be damaged. I do have a question though, where did that number come from that you listed for the board? GE usually start with 2 letters than a series of numbers, not like you have listed
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
The f7 number keeps beeping on my GE profile range. i am assuming the oven is no longer working as nothing happens when i push the bake button. the most annoying problem is that f7 beeps all the time; it...
F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
you have a stuck button on the key pad you will need a new control board to fix this.
goto http://lartoday.com/order_parts.htm , enter your full model number and search for control
levi
Lebarchrigen Appliance Repair
Mt. Holly, NJ 08060
www.lartoday.com
The numbers that are on the letters on the key board are stuck on
you prbabley just need to hit shift 10 times and turn that function off or press and hold it for 8 seconds (shift) and turn that off too.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
