Question about Lenovo ThinkPad Computers & Internet
Lenovo g500 bios access
I am unable to access the bios and I want to load a different OS onto this machine - I can't boot to the DVD because I can't get to the BIOS and the DVD is currently locked out in the BIOS
Near the power button there is a smaller button. Instead of power press this button and a menu will appear. You just have to choose BIOS Setup or Boot menu if you just want to change the boot order.
Posted on Oct 31, 2013
Press Fn +F1. This will get you in the boot menu and Fn+F12 for the BIOS.
Posted on Sep 19, 2013
  • 1 more comment
  • Mahyar
    Mahyar Oct 13, 2013
    Fn+F12 --> Boot Manager
  • Mahyar
    Mahyar Oct 13, 2013
    Fn+F2 --> bios ( InsydeH20 Setup Utility )
  • jjr_india
    jjr_india Jan 29, 2014
    yes you r right it worked thanks
    New Friend:
Laptop lenovo G500 Turns On But Not Screen
Posted on Jan 15, 2015
  • malak
    malak Jan 15, 2015
    laptop lenovo G500 Turns On But Not Screen
    New Friend:
Thank you so much for help
Posted on Feb 28, 2015
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 2110 Answers
SOURCE: how to reset bios password FOR LENOVO 3000 LAPTOP
You can reset BIOS password by removing CMOS battery from motherboard and re insert again...
Posted on Dec 10, 2008
Anonymous
  • 162 Answers
SOURCE: lenovo g530 4151 - restore bios from USB or CD ?
Hi, What I would best sugget you if you this kind of issue is to restore your system to its original settings, just look for the small button just beside the power button on your keyboard, it has an arching arrow logo, that key is what we called One Key Recovery that would restore your system to its original factory settings. but just a hint it would also delete everything on your computer so consider bucking up every important files taht you have before proceeding with the recovery. also make sure that the ac adapter is plugin before you press the one key recovery button then it will give the options to choose from, just choose one key recovey then proceed with the factory default recovery, thats it it would now proceed with the system factory default restoration. If you still need some clarifications regarding this issue you could also call the tech support hotline of lenovo
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-
6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope that helps you.
Posted on Jun 02, 2010
David Joseph
  • 75 Answers
SOURCE: Unable to get into BIOS SETUP
hi there,
On most systems, the key or key combination to press to enter the BIOS program is displayed on the screen when the system boots up, at the time when the BIOS is ready to enter Setup.
take a look at some default keys:-
  • {Delete} (modern Award and AMI BIOSes)
  • {F2} (modern Phoenix BIOSes)
  • {Ctrl}+{Alt}+{Esc}
  • {Ctrl}+{Esc}
  • {Alt}+{Esc}
  • {Ctrl}+{Alt}+{S}
  • {Insert}
  • {F1}
Posted on Apr 16, 2008
rickyostrom
Ricky Ostrom
  • 274 Answers
SOURCE: thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Posted on Nov 19, 2008
Dvd drive not seen in bios
Your computer's BIOS is an critical part of your system when it comes to hardware integration. This especially true when it comes to setting up hard drives and optical DVD drives. You can access your BIOS settings menu during the boot process of your computer. Different computers have different protocols when it comes to accessing the BIOS settings but many can be accessed by pressing "F1" or the "Delete" key before the operating system is loaded up. Consult your computer's documentation or pay close attention to your boot prompts displayed on the screen to enter the BIOS settings menu.
Turn on or restart your computer system. Press the appropriate key during POST in order to load the BIOS settings screen. You will have a short window of opportunity to press the appropriate key before the operating system loads. Search your BIOS menu settings for the appropriate menu concerning your attached hard drives and CD/DVD drives. If you are not sure where to navigate, consult your computer's owner manual. Check the drive menu to see if your DVD drive is listed. Many BIOS manufacturers give the user the option to scan for attached drives if the component does not appear to be listed. If the DVD drive does not appear after the hardware scan, turn off and disconnect your computer, take off the case cover and double check the data and power connections to the drive. Check the jumper settings on the back of the drive if it is of the IDE variety; SATA drives do not have any jumpers to set. There are three jumper settings for IDE based DVD drives: "Master", "Slave", and "Cable Select". Make sure the jumper is set to "Cable Select". Put the computer back together and plug it in. Turn on the computer and re-enter the appropriate BIOS settings menu. If the DVD drive shows up on your drive list, your computer has recognized it properly. Enter the boot settings menu of your BIOS. Change the boot order of your DVD drive to the first position so the computer will read it first during start up. This step is optional; however, you may wish to have this arrangement in case your computer needs to be started from a DVD boot disk later.
Feb 12, 2013 | Acer Aspire 5742Z-4200 Notebook
When a SATA CD/DVD-ROM Drive is removed, the system fails to boot! Crazy! I just used the drive to re-load the machine but has to remove it. The moment it is removed, the machine fails to boot pas the...
Hi.
Go into the BIOS and set the BIOS configuration to its default settings. Save the changes and exit the BIOS.
When the computer restarts see if it will boot past the Windows logo.
Please let me know what happens.
Good luck.
Jun 09, 2011 | IBM ThinkCentre M50 8187 Desktop PC -...
Unable to boot at start up
well try these...
if your bios is locked then you have to take your hard drive and boot from another device and install the initial step of OS. thats is copying of initial files..
and if your bios is not locked then goo to the boot menu and select your CD/DVD drive to boot from ,
insert CD/DVD and install OS.
i hope it helps you
Apr 09, 2011 | MSI Wind U100-030US Laptop
I am presently using fedora12.now i want to install windows 7 is it possible,they cannot taken any booting from the cd,by default grub installer is loading
Hi Thanks for your question
In order to boot from the CD drive you must change the Boot Order in BIOS.
In order access BIOS you must press certain key on the keyboard during start up. Depending on the machine it may be F1, F2, F3, F10 or Delete key. Once you acces BIOS you must find Boot order settings. Again depending on machine this may look different, but most of the time it's a separate Tab or settings may be in general part in BIOS setup. When you find it you have to place CD/DVD drive on the top of the list of Boot Order and before exiting BIOS sace changes. Now your machine should Boot up form CD and you should be able to install Windows 7. Do not hesitate to ask more questions if further assistance is needed. Good Luck
May 08, 2010 | fedora Linux Operating System
I HAVE TRIED EVERYTHING THAT WAS RECOMMENDED TO ME....CMOS JUMPER RESET,Esc WHEN TURNING THE PC ON, F8 WHEN TURNING PC ON,etc...and STILL NOTHING IS RESPONDING...I'M JUST TRYING TO LOAD MY OS ON NEW HDD...
Go into BIOS settings and change the boot order to boot off CD first. Once that's done, insert your OS CD in the tray and reboot. Your machine should then load the OS right from the CD. Post back if you need directions on how to change BIOS settings. It's usually F2 when the machine boots up but can differ according to your machine.
Greg
Aug 28, 2009 | Dell Dimension™ B110 PC Desktop
Concerning a thinkcentre ibm 8183 pentium 3: I put in a blank new hard drive and am wanting to instal a new os from the dvd drive...using f1 to get to different boot options..i choose boot from dvd drive...
your bios settings are not saved because of low voltage of CMOS cell.
Change your cmos cell from motherbord.
CMOs cell gives power to bios flash memory so settings saved.
Aug 15, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Sony Vaio PCG-6L7P unable to boot. Unable to load
HARDWARE PROBLEM, TRY TO RESET THE BIOS OR REMOVE THE REMOVABLE DISK CD/DVD ROOM, THEN USE EXTERNAL
Jun 26, 2009 | Sony Computers & Internet
New 100gb MK1031GAS hdd not recognized in bios
you fit a new hard drove and it is a blank page
of course the bios will not recognize it
you have to get into bios and change the boot sequence from hard drive to cd as first boot preference
shut down the lap top, after loading the cd in the cd unit then restart
the bios will boot from the cd and install the operating system onto the hard drive
When done ypu can get back into bios and reset it to first boot from hard drive
Feb 03, 2018 | Toshiba (MK1031GAS) 100 GB Hard Drive
Changing Sony Vaio BIOS
you should be able to exit and save changes, which my guess is you are exiting without saving the changes. theres is a way around this, by pressing either F8, F9, F10, or F12 to access the boot menu, and then you can boot from cd to install your linux operating system
Jan 09, 2008 | Sony VAIO PCV-RX511 PC Desktop
Computers & Internet Logo
25,756 people viewed this question
Top Lenovo Computers & Internet Experts
Ekse
Toby Lee
Toby Lee
Sunny Solanki
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
