I cannot get the temperature on my infrico double sliding door fridge below 16
SOURCE: I have a Samsung RS21DPSM
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
SOURCE: fridge too cold
check the damper control and damper door between the freezer and refrigerator compartment to see if its iced up in a fully open position,if so thaw it out and then see if it moves as in opens and closes when the cold control in the refrige is adjusted,if not replace the cold control
SOURCE: I'm unable to set GE Profile Arctica ridge to recommended temp
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
SOURCE: Samsung Cooltech SL-L551DP fridge Freezer.
Hello, The answer to these questions lies in the way the
freezer/fridge combo works. The freezer is where the cooling coils are located.
Then air is moved over the coils and circulated through the fridge side by a
small blower or fan. The problem arises when the air is not circulated for some
reason.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The reasons the air is not moving is usually two reasons
The first reason is pretty simple to fix, you simply replace the air circulator
and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is
defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance
through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical
timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on
it's own will get you going temporarily, till parts can be shipped to you. That
will melt the ice and give you a few days or a couple of weeks till it ices up
to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
By methodically checking these parts you can isolate
your problem and fix it.
Take care.
SOURCE: I have a Samsung SRS594HNSS
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
