20 Most Recent
Sentry Fireproof Safe Questions & Answers
How to open Sentry V330 with combination and key?
3 Digit Combination Lock
31-10-31
- NOTE: If your safe DOES NOT have a key, skip Step 3.
- Turn the dial to zero.
- Insert your key and turn it until the plunger pops out.
- Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
- Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
- Turn the dial to the left to the last number (stop the first time on your last number).
- Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of Sentry Safe models:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
I cannot open my safe.
try holding the # and the * key for 5 seconds that should reset the safe and open it up
Sentry H4100 file safe
There is a lock and there is a latch.
You can latch the safe without locking it and unlocking it does not unlatch it.
After you unlock it, then you must press up on the spring loaded latch while (this important) pressing down on the cover to releast the pressure on the latch hook, allowing it to move out of the way. After the latching hook is out of the way, you can release the pressure on the lid and it will open. You can't see the latch hook as it drops down from the lid, into the front wall of the safe where it engages a post, but perhaps you can imagine what it looks like.
Mine will not unlatch, even though it is unlocked, unless I press down on the lid to give it clearance first. There is quite a bit of spring in the plastic that this safe is constructed out of. It works against you when you try to open it and close it.
I can take digital photos of the mechanism if this description does not help.
Another Gary
I changed the batteries in
Try the factory code shown at the front of your manual. You can find the a user manual on the Sentry website.
What is the
sentry 6380
I have cracked many codes by just feel and using the lever to feel the drop! The first right turn after three complete revolutions of the dial has one long pause and the rest short! After the long pause is the first in the combination, the left one same thing after one complete revolution, then right again pulling the lever down every drop meticulously. DONE!
Can't open my Protocol Home Safe - Electronic Keypad Entry
Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
