Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Posted on Jun 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What cause double images on my t.v.?
Double images appear on my t.v.?
Sonny Berry
Level 3:
  • Philips Master 8,617 Answers
  • Posted on Jun 12, 2009
Sonny Berry
Philips Master
Level 3:
Answers
8617
Questions
Helped
1723430
Points
23750
The convergence ICs and resistors have failed. Heres a link to the repair kit for your model which contains the parts and step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Technika TV bought April. 2013. Flickering picture and double vision appearance(as if 2 non aligned images). Same on DVD or Sky channels. Help.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
My sony kdl-52xbr5 52 in. has double images within the first 7 minutes
Sounds like you have a bad LCD panel. Go to youtube and search Sony LCD tab problems, and you will find several videos showing you the problem and possible fixes!
1helpful
Picture appears concave and doubled
Most likely scenario is that the auto convergence option has disappeared which will cause the set to have an arced picture with double images. You can get the RCA repair kit called ITC222 & ITC222A convergence option missing repair kit from www.tvrepairworld.com which has the replacement parts and the CD with instructions.
1helpful
The screen has a double image and also has a
u have bad convergence , this is a problem from the deflection board , the repair of this repair is about $250
2answers
Want to downgrade from vista to xp but have no disk
http://www.utorrent.com/
http://thepiratebay.org/torrent/5388204/Windows_Xp_Genuine
http://www.mediafire.com/file/yznzmdonjgm/Nero 7.rar
ok this is a wiodws xp sp2 genuine ...all you have to do is following my indications..
1st link it is a utorrent program to help you download the image file with windows xp....install it first
2nd it is the actuall windows in image format ...download it using the utorrent...just click download torrent..and when the download appear open with (browse) u torrent...and will download it into computer (My documents /downloads..)
the 3rd it is Nero 7 ..you will have to install it to be able to burn the image to cd ...cause this image is burning by double click on it ...and it will open nero automatically If you have another program for image burning ..and it is sees the image file ...use it cause it is the same ..the idea is to open from the image by double clicking ..and not to make a regular cd ..cause it will not be boot-able..
after burning the cd with success..get the cd key from the folder cause you will need it during the installing and that's all..
insert ..restart ..when it prompts you ..press any key to install (boot from cd )..
if it doesnt ask you to burn from cd ...go to bios and change the boot priority ...and make the cd /dvd the first boot device ...save with f10 and restart to try again..
Fault code J50 & dark strip.
This is for a Mita 1560 Photocopier (analog)
J50 was caused by exit sensor not sitting correctly in its bracket,I fixed this by pushing it until it
clicked back in.
The dark lines & double imaging can be caused light getting onto the drum ,or if the drum gets
cold (so I have been advised) which one it was for sure I will never know because when I
returned the next day & fixed the exit sensor the copy was OK.
Double imaging on paper
Yes, the toner is not being cleaned off, you will need t change the roller, it can also cause jamming
1helpful
HC-P4241W
you need to replace STK 392-110s these are your convergence chips and will cause this problem some are stk 120s 150s,up grade to 180s.
Colors and Images
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
