Problems with Philips 51PW9363 51 in. Rear Projection HDTV-Ready. White colors glow on the TV....
(More)
Problems with Philips 51PW9363 51 in. Rear Projection HDTV-Ready. White colors glow on the TV. everything else seems fine. i have adjusted the setting and nothing seems to fix it. what do i do?
phillips projection tv hd connected approx 6 years old. Picture gets smaller suddenly on some...
(More)
phillips projection tv hd connected approx 6 years old. Picture gets smaller suddenly on some channels on its own... like normal is suddenly letterbox or smaller. On some stations picture is jumpy or like slow motion but sound is fine? What might be wrong and with age is even worth trying?
I have a philips 55" DPTV335. When you turn it on it makes a zip type sound and the center bulb...
(More)
I have a philips 55" DPTV335. When you turn it on it makes a zip type sound and the center bulb lights half way. The other two bulbs do nothing. No picture??
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
