While watchingT, the speakers make a crackling sound occasionally... Last 10-15 seconds then stops...
(More)
While watchingT, the speakers make a crackling sound occasionally... Last 10-15 seconds then stops for a few hours....weird!
My 42'' plasma (model 42PF9631D/37B) doesn't turn on. Red indicator light blinks on the bottom...
(More)
My 42'' plasma (model 42PF9631D/37B) doesn't turn on. Red indicator light blinks on the bottom right. I've unplugged several times to no success. The owners manual doesn't indicate what the red light means. Any idea what is wrong?
my philips flat panel 42pf9631d powered down on its own and never turned back on. No lights or...
(More)
my philips flat panel 42pf9631d powered down on its own and never turned back on. No lights or anything.The electricity is working in the wall, so I know it has power.
Hello, The picture never comes on and the power supply light goes from green to a red flashing...
(More)
Hello, The picture never comes on and the power supply light goes from green to a red flashing light. It flashes at an interval of 7 times before pause. What is your suggestion?
I have a 42" plasma TV, when I turn it on I get the "green" indicator light that...
(More)
I have a 42" plasma TV, when I turn it on I get the "green" indicator light that after a couple seconds starts flashing red, and the TV will not come on. what does a "red" flashing indicator light mean? I've checked all connections and everything seems to be fine.
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
