Samsung CLP-510 Laser Printer Logo
Posted on Oct 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Waste motor error
I have the message waste motor error how can i fix it?
  • Deanoskill Nov 21, 2007
    Had same error message. Must admit it was preceded by the Replace Waster Toner Bottle message (MORE CONSUMABLES, MORE COST!) which was displayed for couple weeks intermittently then stayed on permanently. I didnt get round to changing it and found I could continue to print by removing it altogether, but then got the Waste Motor Error message. My own fault, but you need it when you need it and you dont know using it will cause a problem. Call out from Samsung (£185) nearly as much as what I paid for it Jan-06.
Anonymous
Level 2:
  • Expert 161 Answers
  • Posted on Nov 02, 2007
Anonymous
Expert
Level 2:
Answers
161
Questions
Helped
104372
Points
283
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
PrintDocta
Level 2:
Novelist:
  • Expert 217 Answers
  • Posted on Jan 12, 2008
PrintDocta
Expert
Level 2:
Novelist:
Answers
217
Questions
0
Helped
142687
Points
337
Two different things here.
FIRST
Waste Toner Tank Full/Not Installed message
Normally this just means what it says.
The waste toner tank can be emptied and re-used, but often the 'sight window' used by the sensor to detect the waste toner level stays dirty and the sensor still can't 'see' that it is empty.
The sensor can fail and give this message even with a new waste toner tank.
SECOND
Continuing to use the printer with a full waste toner tank will have the waste toner 'backup' in the wase toner augers. This causes the waste toner motor to stall, or draw excessive current.
The cure often requires a new waste toner motor assembly.
As the service manual states
"Replace the waste toner tank immediately or the printer may be damaged"
The waste toner motor error can also happen after a transfer belt splits dumping toner everywhere inside the printer. Transfer belt splits usually happen after the Transfer unit continues to be used well beyond its rated 50,000 image life (NOT a good idea to reset the counter on this item). Later CLP-510 printers would not permit the resetting of the Transfer Unit counter in order to try to prevent this happening.
2 Related Answers
PrintDocta
  • 217 Answers
  • Posted on Sep 17, 2008
SOURCE: Waste Motor Error message on Samsung CLP-500
This error is caused by the Waste Toner Motor 'stalling' - usually as a result of the Waste Toner Full message being ignored for too long, and the waste system becomming overful.
Usually best to replace the Waste Toner Motor assembly.
They are for sale on auction websites from time to time.
Anonymous
  • 726 Answers
  • Posted on Oct 02, 2008
SOURCE: waste motor error
How i can fix this problem 929:fatal error .
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
2answers
Waste motor error
2answers
000110-0001
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
104helpful
13answers
Cannon ir 3530 all error code and solution
1helpful
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
14helpful
4answers
E000019-0000 in cannon 3300 xerox
E000019-0000 indicates that the Waste Toner container is full.
5helpful
CLX 3160 waste toner tank error message
Empting the waste toner tank does not always fix this problem. Samsung shines a light through the tank with a photo receptor on the other side. If it the photo receptor does not see enough light, it will trigger the replace waste tank message.
You can fix this by trying to clean the clear window portion of the tank with a q-tip. This is difficult to do since there are parts of this window which is hard to clean with a q-tip.
Or you could wash it out with soapy water until the window is clear of toner. Allow the tank to dry and reinstall.
1helpful
My Ricoh Afficio 2232C doesn't print and it gives me this message: "Functional problems within your computer. Turn operation on then off. If the error appears again, call service. SC 440-01."Several times...
A 440-1 is a black drum motor lock. The waste toner in the black pcu is backed up, more then likley. It is not easy to fix. You could replace the black pcu but it will happen again. The usual problem is oil in the main waste toner system. It clumps up the toner and clogs the part where all the waste toner comes together for entry into the waste toner bottle.
1helpful
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
