Troubleshooting & Support
Hot Topics:
- reset
- 310 red
- paper jam
- dev home error
- red status...
- imaging unit...
- reset 310
- check toner...
- pickup replace...
- spl error...
- drum reset
- transfer belt...
- 310
- red light
- drum cleaning
- transfer belt...
- lines
- SPL
- blades clean...
- service manual
- smudge
- paper feed
- poor print...
- clean lsu
- status red
- imaging unit
- fuser low heat
- reset counter
- reset transfer
- samsung clp 300
- View All »
Problems & Solutions
Where to download the driver for Samsung CLP-300...
Go to http://www.samsung.com/uk/support/model/CLP-300/ELS-downloads?isManualDownload=true and select Drivers from the left hand...
ink there. My printer does not pick up the paper
The pick-up roller at the rear of the printer probably needs to be cleaned using an alcohol solution as over time it picks up dirt and ink...
How do I empty the
in above the drum of your catridge, there is the waste container. a rubber blade is there which **** the wastes into the container and that...
Can you please advise me that if a coloured light
page42 of the online manual states that a blinking color light means that toner is low, and needs replacing soon. if the light stays on, the...
printer makes grinding noise when I turn it on. I
Welcome to Fixya Common problem for the red light is the waste toner. Power down the printer. Take out the waste toner and empty it. Put it...
My black ink is really
Sounds like toner build up on your developer blades in the imaging unit. If the black look like this: The problem is with the developer in...
when i connect my printer
There is a lot of problems that can cause the light to turn red, such as paper jam, low toner, full waste toner tank, etc. The only real way...
On printout are vertical streaks.
Welcome to Fixya Sounds like metering blade needs cleaning. Please see procdeure below: Tools you will need: #2 Phillips screwdriver Small...
Red Light comes on and wont print
There is a lot of faults that cause the red light to turn on, toner cartridge empty, waste toner tank full, paper jam, imaging unit...
faded black print. Installed new toner. Still
If you are getting vertical faded streaks in the black print like this: The problem is with the developer in the imaging unit. The problem...
why is my samsung clp
Is the printer making a clicking sound when it is printing? Or is it just making a clicking sound but there are no light and the printer...
fuse over heat error and replace transfer belt On
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
I've lost the pinter installation
Go to this link http://www.samsung.com/us/support/downloads/CLP-300 Here are all the things you'll need with your Samsung. Note that you...
RED STATUS LIGHT WONT PRINT
There is a lot of conditions that will cause the red light to come on. This includes, empty toner, waste toner tank full, paper jam, etc....
Printer worked fine for a long time, then black
Hello, Issue seems to be linked with the printer's scanning unit. Thanks
Unsolved Problems
I keep losing my connection to my Samsung CLP 300...
I am losing the connection to my networked Samsung CLP 300 but only with one computer running XP Pro sp3. It was...
the photos on the fixya site will not open
the answer is on the site but the photos will not open
How do I clean the pick up roller
My paper won't pick up and I saw that cleaning the pickup roller will fix it but there's no instructions...
My print screen is torn. How can I replace it?
Its the second time my print screen breaks (2 printers bought) My friends print screen never broke. I don't feel...
white spots appear on page
I am printing onto glossy card 180gsm and white spots keep appearing down the page. I have barely used the printer and...
How to clear build up of toner on developer blades...
I get a streak of print down one side of the page, which I believe is caused by build up of toner on the developer...
Upload a manual for Samsung CLP-300 Laser Printer
Specifications
TopKey Features
Full Product Name:Samsung CLP-300 Laser Printer
Platform:PC, Unix, Mac, Sun
Technology (Detailed):Color Laser
Max Resolution (Color):2400 x 600 dpi
Black Print Speed:14 ppm
Output Type:Color Printer
Max Resolution (BW):2400 x 600 dpi
Color Print Speed:26 ppm
Printer Type:Workgroup
System Requirements
Operating System:Apple MacOS X
Operating System:Microsoft Windows 2000
Operating System:Microsoft Windows 98
Operating System:Microsoft Windows Millennium Edition
Operating System:Microsoft Windows 2003
Operating System:Red Hat Linux 9.x
Operating System:Microsoft Windows XP Home
Operating System:Red Hat Linux 8.0
Operating System:SuSe Linux 9
Operating System:SuSe Linux 8.x
Technical Features
Form Factor:Stationary
Connectivity Technology:USB 2.0
Connectivity Technology:RJ-45 Network Adapter
Duplex Printout:Manual
Monthly Duty Cycle:20,000 - 49,999 (Small Workgroup)
Monthly Duty Volume:24,200 Pages
Language Simulation:SPLC
First Page Out Time:14 Seconds
Dimensions
Depth:13.5 in.
Height:10.4 in.
Width:15.4 in.
Weight:30 lb.
Media
Media Type:Transparencies
Media Type:Plain Paper
Media Type:Envelopes
Media Type:Labels
Max Media Size:Legal (216 x 356 mm, 8.5 x 14")
Total Media Capacity:100 Sheets
Processor
Processor Speed:300 MHz
Memory
Installed RAM:32 MB
Max Memory:32 MB
Networking
Networking Type:10/100BaseTx
Data Link Protocols:Ethernet
Data Link Protocols:Fast Ethernet
What's your problem?
Fix-O-Meter
315,357
315,357 people have viewed this product
- 1,620 people asked about this product.
- 796 people found solutions for this product.
- 22 people have added this product.
After you fix a...
How to resolve...
Getting help...
