The switch is curved so when you close the door the light will also close.How do you know if the light is on when the door closes?Try pushing on the switch and you will see that the light will close.If that is what you are asking.If you push on the switch and the light stays on then you have a faulty switch. hope this helped:)
SOURCE: HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.)
from 704MR***** to 801MR*****
Subject
Lamp Cover Melting Improvement (LG 3D Basic) / 2nd
No.
Loc No.
Before Change
After Change
Note
K-Code
Remark
Part No
DESC./SPEC.
Part No
DESC./SPEC.
501A
6871JK1011A
PCB Assembly,Main /
6871JK1011D
PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08
C
Change Relay SPEC.
503F
3111JJ1001X
Case Assembly,Display /
WINNER1 BASIC BRAND
ABQ33905315
SOLO PARA SERVICIO, NO PARA PRODUCCION
C
Thermoprotector addition.
503F
ABQ33905304
ABQ33905315
C
409B
6912JK2002C
Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE
6912JK2002E
Lamp,Incandescent /
C
60W to 40W
no, there is an on/off switch next to the temperature dial, when its on the light in the fridge stays on when door is closed and light goes out when the siwtch is off when the door is closed, i have cheched by pressing the button that is in contact with the door when it closes?
