20 Most Recent Bosch B22CS80SNS (220 cu ft) Side by Side Refrigerator Questions & Answers
Does ANYTHING work? Sure it's plugged in, breaker not tripped and GFI plug not tripped?
Plug something else into the outlet to confirm that it works.
Unplug from wall for 30 minutes to reset Bosch to defaults.
Still malfunctioning? Main control board is faulty.
Bosch B22CS80SNS... | Answered on Jan 09, 2018
if you mean light for water and ice dispenser they upgraded to a new led ring mine went out to you can get part from bosch parts website
Bosch B22CS80SNS... | Answered on Feb 01, 2017
Hi, it sounds like the thermostat for the refrigerator is not shutting off and just continuing to cool to the point of freezing . You need to get it checked out and renewed .
Bosch B22CS80SNS... | Answered on Jan 07, 2016
Do you see a button called alarm/lock?
Press and HOLD that button for five seconds.If that does not work,Press and hold super and freezer buttons at the same time for five seconds.This would change the IWD off message.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Bosch B22CS80SNS... | Answered on Nov 25, 2015
The power cut may have damaged the compressor. If it overheated trying to restart it may just click on and off for a while. Check if the compressor is hot and running.
Bosch B22CS80SNS... | Answered on Aug 03, 2015
We have the same fridge, we just had the same problem, and followed the instructions found on this website. Probably a clogged drain pipe/tube.
After following these instructions, my husband found a chunk of debris in the tube along with a piece of plastic wire tie that was the probable cause of our issue - here is a copy of what we did last night. (The end of the tube has a little rubbery opening that drips into a pan at the base of the rear of the freezer - the beginning of the tube is behind the grill on the back wall of the freezer, have to put the wire through the grill and into the hole - we put the wire up from the bottom and down from the top to be sure to get the clog)
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Bosch B22CS80SNS... | Answered on Aug 02, 2015
More than likely you need to change your filter or you may have a bad water valve. Good Luck!
Bosch B22CS80SNS... | Answered on Jul 25, 2015
The serial number is located on the inside of the refrigerator section, on the right side of the first vegetable bin on the panel.
Bosch B22CS80SNS... | Answered on May 21, 2015
You can go to the Bosch website for some help. When new it comes with a hose to plumb in for water and ice.
Bosch B22CS80SNS... | Answered on Mar 21, 2014
Bosch B22CS80SNS (220 cu ft) Side by Side Refrigerator Logo
55 questions posted
Top Bosch Refrigerators Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Bosch Refrigerators
  • Bosch Refrigerators
Most Popular Question
freezer temperature rising alarm
  • Refrigerators
