I cannot get the cover off to check possible loose connection on the interior light on Smegfab28....
(More)
I cannot get the cover off to check possible loose connection on the interior light on Smegfab28. Have changed bulb numerous times but still no light ! Any ideas ?
How do I remove Smeg FAB 28 Fridge door,as I have bought a new replacement but it has not...
(More)
How do I remove Smeg FAB 28 Fridge door,as I have bought a new replacement but it has not instructions
Freezer is fine but fridge is wet which I suspect is because the doopr seal is not good. Where can...
(More)
Freezer is fine but fridge is wet which I suspect is because the doopr seal is not good. Where can I find a replacement seal and will I be able to do it myself - (very poor DIY person!)
My fab28 is just the same. Full of water, probably due to the ineffective door seal and seal on...
(More)
My fab28 is just the same. Full of water, probably due to the ineffective door seal and seal on freezer compartment. I can get a new freezer door but cant find a replacement door seal. Any one know where I can get one?
The seal on my Smeg Fab 28 fridge door needs replacing. But how do you get the door apart to change...
(More)
The seal on my Smeg Fab 28 fridge door needs replacing. But how do you get the door apart to change the seal?
How do I remove the door switch off my fridge as the light doesn't work? Also does the light switch...
(More)
How do I remove the door switch off my fridge as the light doesn't work? Also does the light switch contain the thermostate?
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
