Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
How to use temperature settings on Bosch Classixx fridge freezer
I've moved into a house which has a Bosch Classixx frost free fridge freezer but no Instructions Manual!! How do the fridge/freezer settings work and when would you use the 'super buttons'?
Posted by shj1402 on
Anonymous
  • 525 Answers
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
  • Anthony Reed Nov 06, 2011
    Not for this Fridge Freezer, Cant find it anywhere
I have lost my instuctions for this Bosch
Problem solved went to Currys and looked at the instruction book in there!!!!!!!
Jan 09, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
We recently moved to a house with a Bosch KGV28V01GB fridge freezer outside but it doesn't seem to be working. Its plugged in and the light comes on when the door is opened. The switch is set to ON but...
Good day,
Refrigerators are designed for indoor use only. The lowest temperature they will perform normally is 55 degrees.
As the temperature drops below that it degades to the point of not working at all.
P.S. If you move it inside, give it a 24 hour warm up period. The oil in the compressor will be too thick, and can even ruin itself trying.
Jan 01, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch classixx frost free fridge freezer
i cannot set the temperature from -12'o to -24'o
Jun 23, 2008 | Refrigerators
Bosch Classixx Frost Free KGU34640GB/06
You have found where the problem is and now you must find what the problem is. The freezer is not defrosting tells you the problem is there. Defrost of the freezer coil is started by a timer, the time energizes the heaters, when termination temperature is reached the defrost thermostat opens, the timer continues until the time expires (18-22 minutes). First locate the timer, rotate the clutch head screw SLOWLY clockwise until on e click is heard. The heaters should come on a defrost take place. If timer restarts the system after the time period check the heaters for continuity. If no reading on an Ohm meter replace the heaters. If you find the heater O.K. by a continuity reading, check the defrost thermostat.
Jun 18, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
Top Bosch Refrigerators Experts
Sheldon Dedek
Jorgie Navito
Jorgie Navito
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
