Question about Bosch B22CS50SNS Side by Side Refrigerator
My bosch refigerator water/ice dispenser is in lock mode, how do i unlock it?
Posted by fdittie on
Lee-Anne
    New Friend:
How do you adjust the temperature on this panel?
Posted on Oct 07, 2015
5 Related Answers
Anonymous
SOURCE: unlock water
you have inadvertently activated the button lock- keep children and other hooligans from playing with the buttons. :)
Hold down the light button until the red key is no longer lit.
Posted on Nov 29, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: how to unlock control lock on ge monogram side by side
shoud be amatter of pressing abutton and holding in for 3-5 secs to unlock. look closely at the control panel it should indicate which button(s)
Posted on Jan 25, 2009
Anonymous
SOURCE: Can't unlock my ice dispenser
press the lock button three times in a row
Posted on Apr 06, 2009
aborcass
Ron Coons
  • 2651 Answers
SOURCE: I accidentially locked the water/ice maker
you should be able to unlock the same way it "locked" by holding one or more buttons down for 3 secs. look closley at the dispensor for which buttons exactly
Posted on Aug 25, 2009
Anonymous
SOURCE: ice maker not working bosch refridgerator
Had the same problem. If there is ice in the bin make sure the ice bin is in all the way. there is a
drive gear in the back that has to be engaged. If the
bin is emty open the little door where you can see
if there is ice, on the left you will see the square
end of the ice maker unit. Slip your fingers under
the front face, palm of your hand facing up so you
can feel the bottom of the front of the unit. Over
to the left you will feel a button that you can not
see. Just push it in for a few seconds and the unit
should start. One other thing, make sure the limit
switch is pulled down, thats the plastic on the
wire which shuts the unit off if it is full. Good Luck.
Posted on Nov 01, 2009
My Bosh Refrigerator / Freezer water/ice dispenser is in lock mode, how do I unlock it
Most electronic fridges have a child lock facility. Usually, you need to press and hold 2 buttons at the same time for a few seconds until it beeps. Not sure of a Bosch but its usually the temp up and temp down buttons. It should say on the display how to lock / unlock
Sep 30, 2018 | Refrigerators
GE Refrigerator Ice and Water dispenser stopped working after power outage
More than likely the user interface board that controls that portion of the machine is probably bad, or, worse case scenario the main control board which has the overall say so for the machine has gone out which isn't uncommon either. My best advice is if your going to do it yourself buy your parts from www.repairclinic.com because of their return policy which you can return any part you bought even if installed/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 19, 2012 | GE GSH25SGRSS Stainless Steel Side by Side...
Just installed a new Bosch fridge, ice dispenser dispenses ice but water does not dispense?
Make sure it has water on the container and no obstruction on the water dispenser. Try several times. Since it was new unit, sometimes water has not yet completely fill the dispenser tubing hence it will not dispense water.
Look for some carton, foam or plastic obstruction around the dispenser, it may cause hindrance of not flowing water from dispenser into the glass.
Thanks for asking.
Jul 03, 2011 | Bosch Refrigerators
The water will not dispense and the ice cubes will not come out. I noticed on the front panel that IWD is "off" and that it shows "lock"ed at the bottom of the screen. I know that the...
Press Freezer and Super at the same time for 5 seconds to turn Ice & Water Dispenser on. This will remove "IWD Off" indicator. If it is locked, press the Alarm/Lock button for 5 seconds to unlock it.
Feb 17, 2011 | Bosch B22CS50SNS Side by Side Refrigerator
Water dispenser not working
There are two electric valves for your ice maker One for water to make ice and the other is for your water dispenser. They can get clugged and will not dispense water. The two valves are sold together for $50 and they are right in the back of your Refrigertor where the water pipe ends. Hard water can clugg those tiny valves
good luck
Jul 31, 2009 | Refrigerators
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Kenmore Elite Fregirator
i have the same fridge, you have to press and hold the Lock button and it will unlock the ice/water for you.
Sep 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Bosch B22CS50SNS Side by Side Refrigerator Logo
Top Bosch Refrigerators Experts
Sheldon Dedek
Jorgie Navito
Jorgie Navito
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
