Troubleshooting & Support
Hot Topics:
- lrfd25850
- lg lrfd25850
- parts
- gasket
- repair ice...
- er 15
- freezer...
- water leak
- frost build...
- latch
- ice maker
- water
- replacement...
- lrfd25850st
- Repair Manual
- broken clip
- BOTTOM FREEZER
- freezer
- lfx25960sw
- drain
- fridge
- light
- change...
- ice maker not...
- ice maker...
- water dispenser
- kenmore
- replacement
- ice build...
- error codes
- View All »
Problems & Solutions
Fridge not getting cold freezer working correctly...
We need to find the reason for the restriction of cold air from your freezer making its way to top of the fresh food section. Because...
I have lrfd25850 refrigerator. I
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in...
ice maker leaks and ice
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt...
fridge not cooling. Shifted house 2 days back.
Your fridge systems under chocked. Whenever transport refrigerant unit you should not lift down wards on suction side which will lead...
the refrigerator is getting warm, but the freezer
Hi, Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling Refrigerator...
About a year ago my LG LRFD 23850TT French door
that's the way it works ;-( you should defrost your frig every 6-12 months. look here for a fix if you don;t do that. Have fun Avi
KENMORE 79577579600 REF. with an error code er-1f
This is an error code for the icemaker fan motor. If the control does not see a signal coming back from the fan motor you will get this...
I have an LG LFX25960SW - 3 door refrigerator. I
the IF erroR is for the ice fan in your freezer it is not working properly or is froze up the control can detect problems with the fan i...
I heard there was a recall on LG fridges, how do I
Look at the cspc.gov site for the models in the recall in the US and then you may have to contact the company (since not all serial numbers...
display is all lit up
try unplugging the unit for ten or fifteen minutes and then plug it back in again. That will reboot the processor that controls the display....
lg refrigerator LFX25960SW
I work on LG/Kenmore elite "Trio"aka french door model about 3 times a day on all kinds of problems. Read through this for both...
LG LRFD25850 French Door, Fix or Repair Daily
You are expereincing poor service. The techs that are working on your unit do not know what they are doing. There is no problem that...
LG LRFD25850ST French Door Refrigerator -
Unplug ref for about 5 Min. If does not fix the board in the door may be at fault or the main board. You may need a service call.
lights stay on inside Sears (really LG) french...
That should be a covered repair. There was a safety bulletin on that. Call Sears and complain. Tech should have known that.
DOOR GASKETS RIP AND TEAR DOORS DO NOT CLOSE
There are six screws on the top of the refer; you need to loosen all six ( that are holding the doors in positon ) and allow the doors to...
Unsolved Problems
Error Code Er CO ...
Initially the display was all lit up, and after re-setting it by unplugging the fridge, it eventually went to the Er CO...
I have a French Door LG Refrigerator. Neither the...
We have the icemaker in the door. We first noticed the problem because water was leaking out of this compartment. . ...
ice water button
no longer functions it's stuck on ice
Error code dh and water/ice pooling at bottom of...
Unplugged and replugged fridge to clear error. Error message returned hours later. And I scrape ice out of bottom of...
Lg LFX25950TT French door ,model with Er FF code...
Code Er FF on my Lg Fridge LFX 25950TT Refrigerato not cooling
Water dispenser won't shut off
The water dispenser won't shut off. It will stop if you open the door or lock the display on the front of the unit.
REFRIGERATORS DOOR ALARM KEEPS GOING OFF
Refrigerator door is closed but it keeps beeping we disconect it for a while then reconect but it continues to beep is...
ice maker does not work. when i turn it on i get
ice maker does not work. when i turn it on i get the error 1F
Manuals & Guides
TopDo you have a manual for LG LRFD25850 French Door Refrigerator? - Upload it to FixYa!
Upload a manual for LG LRFD25850 French Door Refrigerator
Specifications
TopKey Features
Full Product Name:LG LRFD25850 French Door Refrigerator
Type:French Door
Total Volume:25 cu. ft. / 708 liter
Fresh Food Volume:17.7 cu. ft. / 501 liter
Freezer Volume:7.3 cu. ft. / 207 liter
Ice Maker:With Ice Maker
Total Number of Shelves:5
Fresh Food Compartment
Fresh Food Shelves / Bins:Egg Storage
Fresh Food Shelves / Bins:Dairy Center
Fresh Food Shelves / Bins:Vegetable Bin x 2
Fresh Food Shelves / Bins:Split Shelves
Shelf Material:Glass
Door Opens:Opens to Left and Right
Light:Yes
Ice Maker
Dispenser:Water
Dispenser:With Water Filter
Convenience
Exterior Color:Black
Exterior Color:White
Exterior Color:Metallic
Controls:Digital Display
Defrost:Automatic
Energy
Energy Efficiency:Energy Star Compliant
Dimensions
Overall Depth:34.25 in.
Overall Height:69.75 in.
Overall Width:35.75 in.
What's your problem?
Fix-O-Meter
42,673
42,673 people have viewed this product
- 323 people asked about this product.
- 101 people found solutions for this product.
- 15 people have added this product.
Pins on the...
How to fix your...
Ice Maker...
