Brother DCPJ125 All-In-One Inkjet Printer Logo
bharat karki Posted on Sep 23, 2013
Unable print 49 - Brother DCPJ125 All-In-One Inkjet Printer
mr.rex
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Nov 11, 2013
mr.rex
Contributor
Level 1:
New Friend:
Answers
8
Questions
Helped
1231
Points
11
Error 49 relates to the print head drive voltage. It may just need the flat ribbon cables that connect the head to the main pcb reseating, but equally it may need the print head replacing (most likely).
An outside chance that the main pcb will need replacing.
In theory, all of these jobs are a task for an engineer.
My Brother printer DCP-T420W shows the Unable Print 49 and also it says that the ink is low when it is not. How to fix this?
"Unable to Print 49" occurs when:
- there is a mechanical malfunction
1. Confirm the error message appearing on the display.
- If "Unable to Print 49," continue to step 2.
- If a different error message, click here to search for that error message to locate the appropriate troubleshooting steps.
step 4.
- If "Unable to Print 49" returns, skip to step 5.
step 5.
Warranty and Service Options.
- If you want to confirm and transfer faxes, continue to step 6.
- If you only want to transfer the Fax Journal Report, skip to step 7.
a. Press Stop/Exit to temporarily clear the error message.
b. Press Settings.
c. Press ? or ? to select Service. Press OK.
d. Press ? or ? to select Data Transfer. Press OK.
e. Press ? or ? to select Fax Transfer. Press OK.
- If "No Data" appears, there are no faxes to transfer. Press Stop/Exit. Continue to step 7 to transfer the Fax Journal or if done transferring skip to Warranty and Service Options.
- If there are faxes in memory, you'll be prompted to enter a fax number. Enter the fax number, including the 1 plus the area code. Continue to step f.
b. Press Settings.
e. Press ? or ? to select Report Trans. Press OK.
f. Enter the fax number, including the 1 plus the area code.
g. Press Black Start. The Fax Journal Report will transfer to that number.
Unable to init. 49
The 49 error code normally means ambient temperature too low. Is your printer in a very cold location? If so, try taking the printer to a warmer location and leaving for a few hours to warm all the components, then power on and try a nozzle (print quality) test from the maintenance menu.
3helpful
2answers
Unable to print49
please go to this link and see video and get the start to troubleshoot step by step.
http://www.refreshcartridges.co.uk/igloo/how-to-reset-purge-counter-on-a-brother-printer/
Your Problem is Solved.
Enjoy the Printing :)
Thanks And Regards,
Piyush Gohil
1helpful
1helpful
Unable to print.49
The error indicates that there is a mechanical problem. Open the printer and look inside for any staples, paper clips, torn pieces of paper, etc.
Hope this helps. Please rate this solution
Randy
1helpful
3answers
6helpful
Brother mfc465-cn unable to init 49
In theory, all of these jobs are a task for an engineer. Brother UK (0870 830 400) can pass you on to a repair agent.
1helpful
Norman Weimar
Norman Weimar
k24674
