Question about Brother MFC-465CN InkJet Printer
Brother mfc465-cn unable to init 49
When I turn the printer on, the menu screen comes up. Then it immediately switches to a screen that says "Receiving data"... followed by the message "Unable to Init. 49".
Once in this state, no button on the printer does anything except "Stop / Exit", which brings me back to the main menu for a minute. However, the "Unable to Init. 49" message inevitably returns.
Does anyone know how to solve this problem?
Thanks,
Lee.
Posted by zamparo on
Anonymous
  • 37 Answers
Error 49 relates to the print head drive voltage. It may just need the flat ribbon cables that connect the head to the main pcb reseating, but equally it may need the print head replacing (most likely).
An outside chance that the main pcb will need replacing.
In theory, all of these jobs are a task for an engineer. Brother UK (0870 830 400) can pass you on to a repair agent.
Posted on Jun 17, 2009
Unable to init. 49
The 49 error code normally means ambient temperature too low. Is your printer in a very cold location? If so, try taking the printer to a warmer location and leaving for a few hours to warm all the components, then power on and try a nozzle (print quality) test from the maintenance menu.
Apr 13, 2015 | Brother MFC-J430W Inkjet All-in-One...
My brother j220 displaying unable to init.49 how can i remove it
The machine has either a mechanical problem or there is something in the machine such as a paper clip or scrap paper.
open up machine and inspect it. use compressed air if needed to clean everything out. If this does not work then unplug for 5 minutes and then re-power on and see if it comes back if so you will need service on it.
here you will find user guide to further assist
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_J220_J265w_J410w_EN_2577.PDF
Jul 12, 2012 | Brother Office Equipment & Supplies
UNABLE TO INIT. 49 (BROTHER PRINTER MFC-J430W)
dear sir, My printer Brother MFC J430 shows unable to clean 49 in display I have found any solve or suggestion in youtube / Google please suggest me.
email. [email protected]
BAHAR LASKAR
SILCHAR, ASSAM
Jun 19, 2012 | Brother MFC 420CN All-In-One InkJet...
My printer Brother MF 5440-CN inject all in one is unBle print as it show unable init, machine error 4F.
Just checked a site - they suggest that you clear the purge counter, maybe this will help
Feb 29, 2012 | Office Equipment & Supplies
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Will not clean servies
Brother MFC-5440CN Unable to Clean error and may work for some others.
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
May 04, 2010 | Brother DCP 115C All-In-One InkJet Printer
Unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Mar 13, 2008 | Brother MFC-620CN All-In-One InkJet...
UNABLE TO INIT
MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Nov 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-465CN InkJet Printer Logo
2,738 people viewed this question
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
