20 Most Recent Brother DCPJ125 All-In-One Inkjet Printer Questions & Answers
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Brother DCPJ125... | Answered on Oct 01, 2018
DCP j125 Inkjet printer stopped printing showing msg. ink absorber is full. What to do?
Brother DCPJ125... | Answered on Dec 13, 2017
Brother DCPJ125... | Answered on Jul 19, 2017
Let the printer brother mfc-j200.
Brother DCPJ125... | Answered on Jun 15, 2016
Remove the power source of the printer
Press the menu button .. Do not leave this button
wait a bit
Press 8
Okay
Press 0
Okay
wait a bit
Use the buttons START (Mono + Color) until it reaches the purge
Press this order figures
Okay
7
Okay
8
ok
ok
Wait until the value turn into zeros
Press exit
Press 9
Then 9
The printer will restart
End
EZZAT FROM EGYPT 002 01277289325
Brother DCPJ125... | Answered on Aug 01, 2015
The ink absorber box or flushing box is nearly full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up. http://support.brother.com/g/b/faqlist.aspx?c=as_ot&lang=en&prod=dcpj4110dw_eu_as&tabid=2
Brother DCPJ125... | Answered on May 11, 2015
Try one or more of these options:replace the carriage PCB
,replace the head/carriage unit,replace the main PCB.
Brother DCPJ125... | Answered on Dec 27, 2014
maintenance 76, press 3 (power) or 4 (turbo) . press mono to start.
Brother DCPJ125... | Answered on Dec 09, 2014
weak connection of flat cables. Check print head
Print head or the PH PCB is faulty
Either the print head or the PH PCB is faulty.
Are the inks full? Have you tried the head cleaning utility in the printer drivers? If those don't work, get the inks out of the printer, soak the print heads in thinners and try the nozzle cleaning utility again.
If that doesn't work i think you may need some new print heads/ink
Brother DCPJ125... | Answered on Oct 07, 2014
Paper jam, do a thorough inspection looking for any stuck bits of paper.
Brother DCPJ125... | Answered on Jul 12, 2014
Brother DCPJ125 All-In-One Inkjet Printer Logo
278 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
DCP Brother
  • DCP Brother
Most Popular Question
ink absorber near full problem brother
  • Office Equipment & Supplies
