SOURCE: Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
SOURCE: HOW DO RESET TONER DISPOSAL FULL,AFTER REPLACING ON A CANON IR 28
You have to enter servcice mode and reset the error code. Press the 'head' key with the star inside it - then the '2' and '8' key at the same time - then the HEAD key again. This must be done fairly quickly and then you're in the service mode. Now, from the screen select 'COPIER' then the 'FUNCTION' key then 'CLEAR' ---->'ERR' ---------> 'OK'. Now turn the machine off and on again. Your code should be gone. If not, you may have to clean the waste toner bottle neck where the sensor light shines through it.
Testimonial: "THANKS ALBERT"
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
