Canon PIXMA MP150 All-In-One InkJet Printer Logo
Posted on Aug 25, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with software
My printer was working good and i was have aproblem with my cd rom it is now dont work any way and i suggest that the comany send me the software for my printer (cannon pixma mp150) because i have some problem with the software cd plz help me
Greg Cann
Level 3:
President:
  • Master 1,114 Answers
  • Posted on Aug 25, 2007
Greg Cann
Master
Level 3:
President:
Answers
1114
Questions
Helped
711083
Points
3906
You can find all the software,driver & manual links on the following page : http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12764 Please update the question & let us know if the information given was useful to you - Good Luck!
  • Greg Cann
    Greg Cann Aug 25, 2007
    Why was my answer unhelpful?
    Were you unable to download the software you needed or do you have some other issue?
    If you don't provide any feedback how can I help you?
    Best regards,
    Informatica.
2answers
Cannot get computer to reconagize printer the software disk is not loading
You can download the software from the companie's website. You should also download the latest drivers, then double-click on them to install them, restart computer and be good to go.
1helpful
2answers
My scanner is not working. Can't open HP director on my laptop. I tried to reinstall CD that came with it, but " more recent version installed" Printer and copier work fine.
Here are some diagnostics.
1. Go to control Panel and then to scanners & camera.
2. look for your scanner there.
3. if you find your scanner there try to scan from the wizard and you will be able to scan you docs.
To Reinstall the Hp Director....
1. first uninstall the HP director software using the removal utility located in your cd...
The uninstaller on the Internet is newer and works better than the one on the CD-ROM. Use this method only if the Internet version is not available. Follow the steps below to use the CD-ROM version only if you cannot get the regular uninstall to work correctly and cannot access the Internet:
  1. Leave the USB cable disconnected from the all-in-one.
  2. Insert the all-in-one CD-ROM into the computer. Cancel or close any installation windows that appear.
  3. Right-click the Start button, and then click Explore . This will open Windows Explorer.
  4. In the pane on the left, locate the CD-ROM drive letter that contains the all-in-one CD-ROM.
  5. There are two different versions of the software for some of these models. Use the file path that pertains to your version of the all-in-one software.
    • Early versions of the HP Officejet 6100 and PSC 2100 and 2200 series: Double-click the file hposcr01.exe , located in the Drivers\Uninst\language (ENU for English, ESN for Spanish, FRA for French, or PTB for Portuguese) folder of the CD-ROM.
    • The newer software version: Double-click the file Cleanall.bat , which is located in the Util\CCC\Cleanup folder of the CD-ROM.
    ONCE THE SOFTWARE IS COMPLETELY REMOVED.RESTART THE PC AND TRY TO INSTALL THE HP DIRECTOR SOFTWARE FROM THE CD.
Let me know for any further help....
http://www.ikarmatech.com
No Usb cord, or cd rom drive to connect
Nope...... Get the USB Cord......That's what it requires to connect........
And the cd rom DRIVE is the optical drive (cd/dvd drives are found ON YOUR PC in the front..That's where THE SOFTWARE DISC (that's what you're saying you don't have) goes.
In other words.......get a standard usb printer Cord or get one from another printer........and make sure you got a power cord for it as well... then it'll work..........
And Here's the SOFTWARE FOR IT.... updated.
http://support.lexmark.com/perl/support/support.cgi
3helpful
4answers
Lost install CD for Canon PIXMA MP160
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Need help connecting printer
Hi marchac01
if you have download the driver you should be able to install with out the CD rom drive
you will need to go to www.hp.com support and drivers type in the the model office jet 6110 then the version of software click it and choose you operating system and down load software. I have included a link that should get you there.
Good luck
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=79477&lc=en&cc=us&dlc=en&submit=Go%20â»&cc=us&lang=en
1helpful
2answers
CANON IR 2016
Software has to be updated using Canon Support Tool, via the USB port and System Software Version 60.02 or higher CD. There is also an outside chance that the Boot ROM chip is bad or just need to be reseatted (with power off of course). Good luck, let us know how you made out.
Wont install
Forget the CD Rom
This suggests you are running a PC with XP and it is not a signatured software.
Windows however can download images without the software
Just plug it in and let Windoes do the work
Cd-rom
CD-ROM not working in Windows 9x, 2000, or XP. If after cleaning the CDs that do not read you're still getting errors ... If, however, the CD-ROM does not work, refer to the next and final possibility
CD-ROM recieving power but does not work. CD-ROM receiving power but does not work. Issue:. CD-ROM receiving power but ... CDs are read by a laser within your CD-ROM drive
Good Luck/Please dont for get to Vote, Thank You.
3answers
LOST CD ROM
you can download direct from internet just find your company supply and check for your model, its free, many sites charge for the service but look for a free download from the supplyer of your brand, becouse you dont estate the brand and the model I can't do it for you........good luck
old marine
old marine
ZJ Limited
ZJ Limited
