Computers & Internet Logo
Posted on Mar 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scanner need help installing the scanner!
Larry Rider
Level 2:
Habit-Forming:
  • Expert 152 Answers
  • Posted on Mar 21, 2009
Larry Rider
Expert
Level 2:
Habit-Forming:
Answers
152
Questions
Helped
44087
Points
450
I could not tell if you are talking about a sound card for a HP PC or a HP scanner, but either way go to hp.com  support and drivers enter make and modal and install driver as instructed.
Hi, I want to install both fujitsu fi 5750c and 5530C2 Scanners in same PC. OS is win XP. I tried through setup, but when one is installed, second one's setup says already having Scanner Utility...
There is no need of installing driver for fi-5530c2 scanner as the driver comes bendled in the fi-5750c scanner. Hence, please install the driver for fi-5750c.On the application, you need to chnage the scanner model under "Select Scanner" menu.
Hope the above information is helpful.
Thanks & regards,
ScanCare
When trying to scan paper the scanner doesn't work.
Hi
Did you install the scanner software, if not, you need to install it again.
If already installed, try to uninstall the scanner driver and set up again the scanner unit.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
This Scanner did not install driver. I need to install mustek scanner 1248ub driver. Software completely install but Driver didn't install.
Disconnect scanner from computer, uninstall the software you installed and restart the computer.
Download the latest driver software from: http://www.mustek.com/mustek/Support.php
Install the driver software but do not connect the scanner until the installation prompts you to connect it or when the installation is complete.
I hope this helps. Good luck!
Scanner says I need to install software
To make your scanner work use HP image Zone (included in your install cd or downloadable from hp's website)
Hope this helps
2helpful
2answers
How to install a memorex scanner model #mem48u
First you need to make sure that you don't have the scanner plugged up. install the software through the disk that came with the scanner. when you have the scanner software fully installed (including drivers) you need to plug up the scanner. if the "New Hardware" notification doesn't show up you need to right click "My Computer" and select manage. Next you need to select device manager. from there you should see a "?" or an "!". click to view these unknown devices. you should see your scanner, select the scanner and you will get a new window. choose the driver tab. finally you need to choose the "update driver" option. then follow the step by step instructions in order to finish the installation of your scanner. please rate me i want to know if i was of any help.
2helpful
2answers
2answers
CanoScan Lide 25 scanner
http://www.canon.com.au/products/scanners/scanners_low_medium_volume/canoscanlide25.aspx try this should give you what you need
18helpful
5answers
Install CanoScan Lide 25 scanner via internet; lost CD installer
just want to know how can i install my scanner, i lost my cd i can't use my scanner since i bought this last july 2008. please help me to find the site to download the program of installing my scannerInstall CanoScan Lide 25 scanner via internet;
Thanks very much
Nono Setijono
Need new software to download scanner information from cd as cd is for windows98/2000/millennium only and my new computor is windows vista.
Downloading the software from the cd wont help you. But you can just try running it and seeing if it will install. Windows Vista needs specific drivers for scanners, if it doesnt detect the scanner and install it then you need to go to the scanner manufacturer website and see if they have an update. or you can use a progra like VueScan, it doesnt need the drivers installed it will install the scanner and allow you to scan whatever u need
Hope that helps
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
