First you need to make sure that you don't have the scanner plugged up. install the software through the disk that came with the scanner. when you have the scanner software fully installed (including drivers) you need to plug up the scanner. if the "New Hardware" notification doesn't show up you need to right click "My Computer" and select manage. Next you need to select device manager. from there you should see a "?" or an "!". click to view these unknown devices. you should see your scanner, select the scanner and you will get a new window. choose the driver tab. finally you need to choose the "update driver" option. then follow the step by step instructions in order to finish the installation of your scanner. please rate me i want to know if i was of any help.
The manual will give you step-by-step guide in the installation of your scanner. You may downlod it from this link:
http://www.memorex.com/support/support_product_detail.php?scc=0&fid=&pid=883&cid=
click on Support for the 48u Scanner under Downloads and you can download the instruction manual.
Hope this helps.
SOURCE: i lost my scanner cd to install ,, please help
Get the driver here:
http://members.driverguide.com/driver/detail.php?driverid=82593
SOURCE: hi i lost my software
You can download the software for your scanner at the following link.
http://www.lostmydrivers.com/driver/download/14903/Memorex/Scanner-Drivers/memorex-mem48u-scanner-full-driver-1.50.
Just enter the characters in the box and click download. After downloading just extract files an install
Hope it helps
regards,
