Once I slam the lid ! down ! then it locks and starts to wash
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
SOURCE: Neptune Washer with lid signal "od"
OK this board won't let me post pics so I'll post as a solution, please everyone you don't need to rate.
Lead on mag switch needs to be re-soldered.
SOURCE: I posted a problem with a Neptune top load washer
The lid lock is bad part # is left side 25001048 runs around $80,the problem tends to stem from the dispensers water and bleach work their way into the switch and I have never had much luck cleaning them out and getting them to work.. and that is left hand side as you are facing the machine.
SOURCE: Neptune TL locked lid light stays lit
foxste
I will give you a few things to try that are non technical and let’s see if the Control Board will let you in Service Mode. If so we will try lock and unlock the washer in Service Mode.
The Service Manual for reference. Sears Parts Direct for reference.
Let enter Service Mode;
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Board Output Test
While in Service Mode, pressing the Delicates key will begin the Board Output Test. This test turns on a
specified output after a key press. (Pressing the Delicates key again cancels the test.) All outputs
will be turned off after five (5) minutes.
Now Press the Colors / Jeans key this should lock the Left and Right Lid Locks….. did it?
If the lid locked now press the Extra Rinse Key and this should Unlock the Left and Right Lid Locks….. did it?
Let me know and we will go from there. I’m trying to get a feel for what Control Board functionality you have……Rich
SOURCE: our power went out mid
Usually if you unplug the unit for at least 3min that should do the trick
