SOURCE: Toshiba 53AX61/ have sound no picture
I have the same problem with the same Toshiba 53ax61 the picture does not work anyone,
Please email me at [email protected]
SOURCE: toshiba 50"rear projection hometheater picture shut off on/off light flashing
take the back off and change the fuse
SOURCE: Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
SOURCE: Toshiba Rear Projection Issues
I had exactly the same problem -- can't remember what they said the problem was but was told it would cost $400.00
SOURCE: Do You Have Any Lenticular Screens Left For 50" Toshiba tz50v51
I found a lenticular screen from Sears Parts Direct.. The were in stock as of 8/29/08
there is a direct tv box hooked up to the tv.
