20 Most Recent Toshiba REGZA 52RV530U LCD TV Questions & Answers
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Toshiba REGZA... | Answered on Dec 30, 2015
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Toshiba REGZA... | Answered on Dec 15, 2015
Should be able download the user manual at Toshiba.com under the support link.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Toshiba REGZA... | Answered on Jun 28, 2015
Try changing the input device to something you are sure, works such as a DVD player. Look for loose contacts of jacks, sockets and cables.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Toshiba REGZA... | Answered on Jun 21, 2015
I'm assuming you tv doesn't turn on but you have the red light indicating power , it's possible you have more than a faulty switch , common fault is the power board has blown one or a few capacitors , you could try replacing the power board on the tv but some tvs will not start if there are other faults , namely faulty inverter , faulty power board , if the display is faulty , it'll be cheaper to buy a new tv
Toshiba REGZA... | Answered on Sep 19, 2014
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Toshiba REGZA... | Answered on May 10, 2014
your backlight PCB board failed. today TV's can be removed and replaced very easy. Disconnect it, open it up and look for the damage board. you can order a new board from the manuture
To know more about this, you have to download the repair manual to this set. Its disassemble section will give you the details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Disassemble procedure to many popular TVs are given with illustrations. Hopes it will help you. Surf the site with patience.
Toshiba REGZA... | Answered on Mar 20, 2014
Toshiba REGZA 52RV530U LCD TV Logo
110 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
not coming
  • Televison & Video
