Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Toshiba Rear Projection Issues
I have Toshiba 42H82 its a rear projection tv, pic is way off on the tv. The way its shows on the screen is attached to the post
any idea is this can be repaired or no , if yes does anyone experienced same issues like this on this tv.
Posted by worldmsart on
  • 1 more comment
  • Anonymous Nov 03, 2007
    It will cost $400.00
  • Anonymous Apr 14, 2008
    My TV's picture is doubled the picture, and it is angled side ways. It is only 3/4 of the screen.
  • Drcliffsr Jul 16, 2008
    My red and white are doubled and look like yours, but straight accross. Otherwise picture is ok. Touch focus says "touch focus error". While running touch focus, the bottom RED line is curved up in the center.
    Drcliffsr
Anonymous
I had exactly the same problem -- can't remember what they said the problem was but was told it would cost $400.00
Posted on May 29, 2008
Anonymous
I have the same problem was told it would cost $800.00
Posted on Jan 15, 2008
Vista Electronics
    Genius:
  • 1,694 Answers
Common problem is called convergence mis-alignment.
A correct repair requires above average technical ability.
Prevent maintenance and correct parts will be needed.
Most repair shops charge about 400.00 for an incomplete job.
Check other Tosh "H" Line solutions already written.....T.
Posted on Nov 03, 2007
My toshiba rear projection TV's picture just went black. Sound is good just a black screen.
high voltage is not coming up. possible fuse locates on power supply board on the right if you are sitting behind set with back off. if fuses are good, possible horizontal output transistor shorted. sounds horrible but easy repair
Nov 10, 2009 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 convergence resistor and pico locations
yes better.  you need schmatic. servicemanuals.net.
Dec 13, 2008 | Toshiba 42H81 42" Rear Projection...
Have a Toshiba 42H82 rear projection TV
Sounds like a power supply problem. You will need your tech again.
Nov 13, 2008 | Toshiba 42H82 42" Rear Projection...
BROKEN SCREEN
Manivain,
The fresnal screen is Toshiba p/n# 23311898, approximately $108.00 the lenticular is p/n# 23311897 approximately $95.00 and the screen protector is p/n# 23311863 is approximately $118.00 all available at Vance Baldwin 800-432-8542 or their web http://www.vancebaldwin.com/ and just click in as a guest.
Bill
Nov 29, 2007 | Toshiba 42H81 42" Rear Projection...
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
No pic no sound
sounds like convergence drive ics or power supply.would be about $350.00 +++ for these type of repairs
Sep 07, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 no sound
Are you using a Cable Box?Using HDMI? Need more Info........
Jul 19, 2007 | Toshiba 42H82 42" Rear Projection...
Blank pic
More info please, how old is the set? How much do you know about tvs? Do you have menus on screen? Do you have Raster?
Jul 02, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
May 29, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
156 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
