I'm trying to replace the filter on my stihl ts 420 asphalt saw and 2 of the srews just keep turning. I took some of the plastic covers off the saw and I can see where themetal threads for the screws have become loose and just keep turning. I have to use the saw on a big job tomorrow and it won't run because they factory made the new models to run like **** when they are do for filter replacement. If you can help me out it would be much appreciated. Thank you
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
SOURCE: I purchased a used Stihl
This was a problem with the original unit. They have since fixed this problem. There is a kit you can get from your Stihl dealer. It is a fuel tank/ air filter kit. You would have to replace the tank housing which is where the air filter bolts up to. You can have the dealer do it, or you can do it yourself. The kit is not cheap, but it will cure your problem. I've used a hacksaw to cut through the old bolts. Then you can change out the tank housing.
SOURCE: how do i get the lower screws out of the filter
I HAD THIS SAME PROBLEM. REALLY NO GOOD SOLUTION.. I WAS ABLE TO REMOVE ONLY ONE SCREW. I HAD TO PRY COVER OFF AS BEST I COULD WITH THE SCEWS STILL INTACT.EVEN AFTER GETTING THE COVER OFF I COULD NOT REMOVE THE SCREWS WITHOUT POSSIBLY DAMAGING MORE OF THE SAW. I CAN NOW SLIDE THE COVER ON OVER THE PROTRUDING SCEWS AND HOLD IT IN PLACE WITH THE ONE I COULD GET OUT WITH A LITTLE HELP FROM DUCT TAPE. THE WORST DESIGN I HAVE EVER SEEN FOR AN EXPENSIVE TOOL. SHOULD HAVE STUCK WITH THE TS400. A SIMPLER MORE PRACTICAL DESIGN. I GUESS THEY EXPECT YOU TO REMOVE AND CLEAN AND OIL THESE SCREWS DAILY. PHIL
SOURCE: Ts420 stihl cut off saw
the jets in the carburetor need to be cleaned out very well to operate this engine
the holes in the jets are very small and clog up easily with in a year or two
Yea it is a stupid design. I was just telling my wife for something that cost over a thousand dollars it is a real stupid setup. Thanks
