Question about Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
Whats the fuel oil mix of sthil ts400 - Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
Posted by Kevin on
Andrew White
  • Stihl Master
  • 2,239 Answers
Stihl two stroke oil mixed ar 50-1, do not use cheap two stroke oil or oil for designed for out board engines.
Posted on Jun 30, 2012
1 Related Answer
snor38
Ron Sanders
  • 118 Answers
SOURCE: how do i set up
The ts400 has 2 adjustment screws. First pop out the rubber gromet to see the screws. The one on the left is the mixture, the one on right is the idle Turn the idle screw in a coup[le turns, this will help the saw run a little fast Now screw the mixture screw in till it bottoms .now back it out 1 and a half turn. Press the decom and pull it thru with the , the choke on a couple times, now pull up onthe decom. Try to start it. when it starts, let it runat a fast speed moving the choke off a click or two when the motor warms up, idle the engine as muchas possible, then adjust the mixture screw in or out torun the best. Squeeze the trigger if engine faulters, it's to lean, back mixture screw out slowly, till it suits you. Reinsert the gromet.
Posted on Feb 25, 2011
What amount of gas and fuel do you put in a Murray 2510 weed eater
50: 1 ratio
use sthil 50:1 special oil and it covers all ratios regardless
one oil mix for all 2 stroke applications
Sep 10, 2018 | Murray Garden
What gas in
normal fuel --91 octane and use sthil oil 50 :1 for all oil mix ratios
Sep 10, 2017 | Cars & Trucks
My sthil saw ts400 when is its runing my blade keeps spining all the time and not stop
Try a little light oil when stationary and unplugged. Place oil centre and turn by hand back and forth. Take outside and protecting your clothing and anything in near vicinity switch on fir about min, switch off then in again then off. Switch off, hopefully solved.
Aug 10, 2014 | Saws
250 sthil weed trimmer burning spark plug with oil
Diana reduce the oil mix slightly in the fuel mix and then give it a few goes to reduce the oiling.
Oct 21, 2013 | Garden
Wot is the fuel mix for a partner k 750 disc cutter
50-1 with Husqvarna two stroke oil, but 25-1 with other two stroke oil as the quaility is unknown, always try to use Husqvarna two stroke oil
Mar 09, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
Need to know what oil goes in the crank of a stihl ts400 disc cutter and the amount
The oil is mixed with the fuel to lubricate all internal components, i would run it at a 25-1 fuel oil mix with good two stroke oil.
Sep 06, 2011 | Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
What is the fuel mix for 359
hi there troyandbec
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Logo
3,547 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
