Question about Stihl Ts 410 420 Cut Off Saw Decompression Grommet
Hi there; my stihl ts 420 does not start easily and it shut off by itself after 5-10 mins work. thank you; masoud
Replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
TS420'S HAVE SEVERAL PROBLEMS, I DO NOT RECOMEND BUYING ONE... THE AIR FILTER HOUSINGS STRIP OUT, THE CARBURETORS LEAK OUT THE RIGHT SIDE THROTTLE SHAFT CAUSING IT HARD TO START AND IDLE AND REVING PROBLEMS, I HAVE ALSO REPLACE ABOUT 25 CYLINDER AND PISTONS IN ONE YEAR ON ABOUT 30 SAWS SOLD.... I WOULD RECOMEND BUYING A TS700 OR LOOK AT OTHER BRANDS, MOST PARTS ON THIS SAW SOME FROM CHINA
Aug 19, 2016 | Stihl Saws
Mar 17, 2016 | Stihl Saws
Apr 13, 2014 | Stihl Ts 410 420 Cut Off Saw...
Aug 16, 2013 | Stihl Ts 410 420 Cut Off Saw...
Mar 25, 2013 | Stihl Ts 410 420 Cut Off Saw...
Aug 15, 2012 | Stihl Ts 410 420 Cut Off Saw...
Jun 22, 2012 | Saws
Aug 29, 2011 | Stihl Ts 410 420 Cut Off Saw...
Dec 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Nov 07, 2010 | Stihl Ts 410 420 Cut Off Saw...
Mar 06, 2013 | Stihl Ts 410 420 Cut Off Saw...
4,442 people viewed this question
Spark plug threads stripped on 420 stihl
Spark plug threads stripped on 420 stihl . Can they be rethreaded
