Question about Stihl Cutoff Saw Starter Recoil Cover Ts 350 360
I have a concrete cutoff saw made by stilht it
I have a concrete cutoff saw made by stihl it back fires when I try to start it. It pulls the cord wright off my hand It is a 2 cycle model. don't know model #
Posted by mmedeiros17 on
anthonysss04
    New Friend:
Depression Valve either isnt being pressed or is loose and popping back out
Posted on Nov 12, 2012
rlev_7
    New Friend:
  • 47 Answers
Clean carb and tune up
Posted on Sep 09, 2010
No fuel to spark plug stihl ts400
could be fuel pipe bent/hole in fuel pipe or yes could be carb
May 20, 2014 | Stihl Concrete Cutoff Chop Saw Clutch...
Ts400 hard starting
Check the fuel tank vent, it could be creating a vapour lock in the fuel tank
Nov 05, 2013 | Stihl Concrete Cutoff Chop Saw Clutch...
Saw runs for awhile then shuts off and continues to run.
i always have to start the saw and then pull the trigger like every 5 seconds for about a minute then it works for me
Sep 18, 2013 | Stihl Concrete Cutoff Saw Carburetor Ts...
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
Stihl Demo saw 400 pulls with no compression
From [email protected] Hi kaqibso these saws are equipt with a decompression switch.It is located on the right side of the unit and has a red cap on it, pull out on it. Best of Luck......
May 30, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
compressed air works well. you really need a gun with a long skinny nozzle. for example
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Saw starts but wont build up any power it fouled two plugs back to back do i have gas mixture wrong
sounds like a rich mixture stihl and huskvarna oil has the same makeup dealers have test tubes for warranty service that tells them what oil was used and will not warranty if wrong oil is used with the proper oil your saw will last for a long time cheap oil does not have the additives needed too keep rings free and inhibit carbon buidlup
Jan 19, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Replace pull cord
i roadworks63. Pull off the right side cover to expose the recoil, remove the rest of the rope. Now rewindthe pully c.c.wise until it stops then release it just enoughto align the rope holes,use a C clamp to hold the pully from unwinding. Insert the rope enough to tie a knotHeat the knot to make it hard,now slowly let the pully re..turn or unwind tieon the handle. You are home free.
May 17, 2010 | Stihl Concrete Cutoff Saw Rewind Recoil...
Stihl Cutoff Saw Starter Recoil Cover Ts 350 360 Logo
465 people viewed this question
Top Stihl Saws Experts
rlev_7
Level 1 Expert
Frank
Are you a Stihl Saw Expert? Answer questions, earn points and help others
