Question about Stihl Saws
Stihl ts400 no spark even after fitting new coil
Posted by Leslie Riding on
Pieter Vleeshouwers
  • Stihl Master
  • 2,027 Answers
I think if you have ordered a new ignition coil without give-up the serialnumber and year of build of the engine as the most important cause in this kind of disappointments because often there can be made a modification on the coil AND flywheel. both on new models and even the sparkplug changed for better heat degree
Some sellers have are not interesting and often do not know about it themselves, but giving the details on forehand there shall be a book opened. in the differences about modifications.
By themselves they do not usually, as long as it sells, because marketing technical based modifications are common on much technical tools and instruments.
Comparable the different revisions by bios on computer mainboards and software
If the right sparkplug and coil and the right flywheel are used then its impossible it will not function IF THERE IS NO PROBLEM WITH THE ' on / off ' SWITCH ...
Posted on Mar 14, 2017
Tim Parsons
    New Friend:
    Problem Solver:
  • 15 Answers
You need to be careful with those ignition modules. Some are mounted on plastic spacers and are fixed with insulated screws. Others seem to stay grounded, I always check the on/off wires and
use a clamp on multimedia over the spark plug wire. Yeah theres a whole range of ignition modules, some with North South magnetic configuration or opposite, some that don't fit in the space, I guess they have to match the type of flywheel disc and the keyway notch. I guess the spark plug lead could be faulty or the spark plug.
Posted on Apr 15, 2017
Ts400 new coil and still no spark, tried 2 new coils and no spark, even changed flywheel and still no spark
did you try a new spark plug? sometimes a new spark plug will do the trick.
Mar 12, 2017 | Garden
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
No fuel to spark plug stihl ts400
could be fuel pipe bent/hole in fuel pipe or yes could be carb
May 20, 2014 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced all...
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Sorry for the bad news (if I am right).
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
I have never seen a flywheel de magnitise, it will be an ignition unit problem
Jan 11, 2012 | Stihl Saws
Wiring diagram for a stihl saw ST400
There is no diagram. it is a simple system the coil for the plug has a kill wire that runs up to the thumb switch.
page 31 of the service manual shows the connectors.
Make sure the wires are not rubbed through.
I am a Gold certified Tech for Stihl. Feel free to ask any other questions you might have.
Jose
link to ts400 manual
Jan 12, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Saws Logo
3,153 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
