? 7:06
https://www.youtube.com/watch?v=AvPv88SELXs
May 1, 2011 - Uploaded by donyboy73
Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Place cutoff saw on floor (flat clear surface). Hold throttle in, while pushing on switch all the way down. Hold cutoff saw firmly. Pull starter handle until saw fires, it should then cut out. Click the starter switch up 1 click to half choke. Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Sounds bad, the only answer here is to pull the cylinder off and check the condition of the internals, if there is a lot of dust behind the filter and into the back of the carb the engine is going to be in need of rebuild.
This sounds like the carb is flooding, there is a rubber tipped needle under the metering side of the carb, this may be leaking, before replacing the needle make sure the air filter is not blocked, replace with a new filter and try again
