I need to service a stihl ts 420 concrete saw and dont know how?
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Posted on Aug 25, 2012
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
SOURCE: need to know belt size fo the stihl ts400 concrete
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Posted on Mar 30, 2011
SOURCE: Ts420 stihl cut off saw
the jets in the carburetor need to be cleaned out very well to operate this engine
the holes in the jets are very small and clog up easily with in a year or two
Posted on Jun 22, 2011
Aug 26, 2017 | Stihl Saws
Mar 17, 2016 | Stihl Saws
Aug 15, 2012 | Stihl Ts 410 420 Cut Off Saw...
Nov 07, 2010 | Stihl Ts 410 420 Cut Off Saw...
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
1,041 people viewed this question
