Question about Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
How do i set up the carburetor on a sthil ts400
Posted by danielleight on
Ron Sanders
    New Friend:
  • 118 Answers
The ts400 has 2 adjustment screws. First pop out the rubber gromet to see the screws. The one on the left is the mixture, the one on right is the idle Turn the idle screw in a coup[le turns, this will help the saw run a little fast Now screw the mixture screw in till it bottoms .now back it out 1 and a half turn. Press the decom and pull it thru with the , the choke on a couple times, now pull up onthe decom. Try to start it. when it starts, let it runat a fast speed moving the choke off a click or two when the motor warms up, idle the engine as muchas possible, then adjust the mixture screw in or out torun the best. Squeeze the trigger if engine faulters, it's to lean, back mixture screw out slowly, till it suits you. Reinsert the gromet.
Posted on Feb 25, 2011
  • john dignam
    john dignam Feb 02, 2019
    the best news now i know how to adjust the fuel and air very helpful .regards john
Original parts diagram for stihl ts400
I found a parts diagram for a Stihl TS400 CutQuick concrete saw here: http://www.sawagain.com/stihl-concrete-saws-1/ . The direct link to the parts diagram is http://www.hellumdiamant.com/filarkiv/File/Sthil/ts400.pdf . I found some of the parts shown in the user manual as well. The manual is available here: https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/TS400_Manual.pdf . See page 44 for that parts diagram.
I hope this helps.
Jul 18, 2017 | Stihl Saws
My sthil saw ts400 when is its runing my blade keeps spining all the time and not stop
Try a little light oil when stationary and unplugged. Place oil centre and turn by hand back and forth. Take outside and protecting your clothing and anything in near vicinity switch on fir about min, switch off then in again then off. Switch off, hopefully solved.
Aug 10, 2014 | Saws
Ts400 doesn't start up, used to start but when it warm up turn off. now it'll nat start at all.
Sounds like it is Over heating to fast take to the shop and see if they can find you a part or you can try changing the fuel in it and set it in full throttle for about 5 seconds and do this for a minute.
Sep 02, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Carb settings for stihl ts 400
Standard settings: screw both in fully, unscrew H screw 1 full turn anticlockwise. unscrew the L screw 3/4 of a turn anticlockwise.
Aug 14, 2012 | Stihl Ts 400 Ts400 Carburetor Carb Rebuild...
Whats the fuel oil mix of sthil ts400
Stihl two stroke oil mixed ar 50-1, do not use cheap two stroke oil or oil for designed for out board engines.
Jun 29, 2012 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
How to set up the carburator on ts400 disc cutter sthil saw
turn the idle screw all the way in and turn out 1 and 1/2 turns the air mixture screw the same then adjust the air mixture to get best running performance at lowest RPM.
Jun 10, 2009 | Saws
Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Logo
11,178 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
