This client worked smoothly with dlink dwa-525 wireless network adaptor and suddenlly can no longer ping another clients. only ping from this client show request timed out. however everything in client is ok and connect icon in tray showing CONNECTED. the other clients work smoothly. i changed windows xp sp3 but this client dont connect to network yet.
SOURCE: Dlink DWL-2100Ap
hi,
you not need software to install DWL-2100AP . just we need visit this website http//support.dlink.com and downlod quick installiton guide.pdf to DWL-2100AP
SOURCE: how to connect dlink dwl 3200AP with dlink dwl
make a repaeter mode
and ip would me same range
SOURCE: cant get accesss to the configuration window
In order to get to the AP, and assuming you just plugged it in, you need to put everything in the 192.168.0.x domain. The AP defaults to 192.168.0.50, so you need to make sure that the router gives out IP addresses that does not include 0.50, or change the IP address of the AP. Likewise, the computer you are trying to log into the AP needs to start in the 192.168.0.x domain, with x being anything but the gateway address (normally 1), or 50.
My guess is you have a router built into the modem and it is giving out different addresses. You can set your network address by hand to be 192.168.0.pick a number like 5 and plug into the ethernet port of the AP (may need a crossover) to get to it.
Post back and let us know what you found.
Carl
SOURCE: D-Link 2100 AP is working in Wireless Client mode.
Check in your router to see if your router is set up to be a DHCP Server. If your router and adsl are both set up to be DHCP servers, sometimes they will fight with each other and some computers seem to have problems getting adresses from this kind of setup. Make sure that only one is set up to give out adresses, then check on your second computer to make sure that it is set to obtain adress automaticaly. If someone has set a manual adress in that computer that is not on the same subnet as the router, they will not comunicate. If this does not solve your problem, try putting in manual adresses into both computers: IE 192.168.1.2, subnet mask 255.255.255.0, Default gateway 192.168.1.1 in the first, and 192.168.1.3 in the second with the same subnet and default gateway,
SOURCE: configure dwl-2100ap
i have one d-link dwl 2100ap. i want configure it tow different netwok.i want two ssid .one can access only interenet and 2nd can access my network and internet.
