20 Most Recent
D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Questions & Answers
Cannot access either dlinkap or
Maybe you have the wrong 192... Go command prompt and type in "ipconfig" without the quotes. scroll up and find the default gateway (default gate way . . . : 192...) and type that in your browser and press enter.
If that doesn't work, go to your network connections and right click on the one that is connected click properties, click on Internet Protocol Version 4, click properties, and make sure all the settings are automatic. Restart computer, repeat first part.
If that doesn't work, reset your router and access point. Than reconnect and repeat first part.
Dap 1320 can't set it up using web browser link
These answers on all these sites are very confusing. Here's what I did to solve the issue of not connecting with a browser. 192.168.0.50 does not work nor does http://dlinkap.local. or whatever else is printed on the device. On my PC that is hard wired to my router, I logged into my router, checked which wireless devices were connected and found that dlinkap (note this is not the SSID that is printed on the device) was assigned 192.168.0.4. Set my browser to 192.168.0.4 and off we go to configure the extender.
Internet setup
It should work "out-of-the-box".
Be sure to connect using "straight-through" (not "cross-over") Ethernet cables.
Connect from the 'WAN' port on the router to your DSL-modem (or cable-modem).
Power-off the DSL/Cable modem.
Power-on the DSL/Cable modem.
Power-off the D-Link.
Power-on the D-Link.
Reboot your computer.
You should be good.
How to reset dlinkap 1320
Hey Rolando,
On the back of the unit is a small button to reset. Use a straigtened paperclip to do so. Attached is an image of what it should look like.
192.168.0.1
If the page does not open then you don't have a connection to the router. Make sure your cable is attached to the router and computer. You can't do the initial install wireless usually.
Ll i need to put password to my accese point (dlink) please tell me how ?
Setting up a wireless router with a Windows client can be complicated.
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes but D-Link provides an easy to walk through configuration system to help you set up your D-Link wireless router.
Plug one end of the Ethernet cable into the DSL modem.
Then plug the other end into the "WAN" port on the back of the D-Link wireless router.
Connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable.
Access the D-Link Configuration Screen
Open your web interface and type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
Use "Admin" as the username and leave the password blank when the login screen appears.
Click "OK." You should now see the D-Link configuration screen.
Set Up General Security
Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button.
Enter a new password under the "Administrator" heading.
Confirm it, and click "Apply."
Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
Under the "Home" tab, choose "Wireless" and select the "Off" option.
Enable Wireless Encryption Protocol (WEP)
Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button.
Use the "Open System" button beside "Authentication."
Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit."
Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field.
Write down the password in a secure location.
Click "Apply." Change the SSID
Change the SSID to make it more difficult for others to locate and use your network by clicking on the "Home" tab and locating the "Wireless" button.
Change the default SSID to one of your choosing, then click "Apply."
Disable SSID broadcasting. Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
Filter MAC Addresses
Click the "Advanced" tab in the D-Link "Configuration" screen and select the "Filters" button.
Choose the "MAC Filters" and click on "Only Allow Computers with MAC Address Listed Below to Connect to the Network."
Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring. Click "Apply."
Bridge will not find router
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes--but D-Link provides an easy-to-walk-through configuration system to help you set up your D-Link wireless router.
Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button. Enter a new password under the "Administrator" heading.
Click "Apply."
Change the SSID
Click "Apply."
How to change password
If you have forgotten this password, you will have no choice but to reset the router to factory defaults.
Reset Procedure: With the router powered on, Press and hold the reset button (on the back of the router) for 10 seconds and release. The lights on the front of the router should all flash and reboot.)-
Reset verizon router password
To reset the router password you have to locate the reset button on the back of the router. While the router is turned on, press and hold the reset button for 10 to 15 seconds. Once released the router should reset. After reset, go to
http://192.168.1.1
You should be able to login using new password.
