Machine is doing complete wash cycle but water is not heating
Possible failure of the heating element. Please check the continuity of the coil and if possible the voltage to the coil , if there is voltage at the cycle then the element is open.
check this link: heating element.
SOURCE: Hoover 600M washing machine cycle issue
Sounds like you may have a timer problem. You might be able to pick one up at a appliance parts center. Most of the time, they can be pretty pricey item, if you can even get one for older models. Check EBAY as well, sometimes you can find hard to find parts for pretty cheap. Replacing the timer shouldnt be that hard. UNPLUG the unit, remove the console, which should be held on by screws, the remove and replace one wire at a time back to the timer. Use caution when removing the timer knob, you dont want to crack it. Most knobs remove by unscrewing to the left.
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
SOURCE: hoover vision hd 1400 washing
I had the same problem. The machine would wash but not drain and the time savers button would blink. Turned out to an eye from a teddy blocking the pipe that enters the drain. I hope this helps.
SOURCE: hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
SOURCE: do you have a wiring
http://www.washerhelp.co.uk/diy-repair-safety.html
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Above is a generic washer although the wiring won't be exact, it still will be relevant, and eminently transposable to this make. If you simply perform the troubleshooting procedures no doubt you would be able to isolate and hopefully repair your problem
http://service.hoover.co.uk/manuals/pdfs/VHD8122.pdf
Hope this is helpful, i could find little on your exact modle.
zwn6120l heating water
the washing machine is not heating water at all
