20 Most Recent Hoover Dynamic DYN8124D 8kg 1200rpm Washing Machine Questions & Answers
temperature sensor has shorted or is an open circuit
Check the wiring to the thermistor and if necessary replace the thermistor
Hoover Washing... | Answered on Jan 12, 2019
You have faulty transmission or/and clutch.
Clutch is on the bottom of the transmission , next to the pully.
Hoover Washing... | Answered on Jan 11, 2019
You have had a leak.
You can disconnect the hose and empty all the water out of it, then leave the hose in the sun to heat up, this will SOMETIMES reset the water stop, if not you will need a new hose.
Error code E09 means there is something the matter with the part in the washing machine control board that drives the motor. Fixing a control board error can be complex. You can try:
Switching off and unplugging your washer when you do this i suggest waiting about 5 minutes before plugging in since your machine can store energy even after a few seconds of being unplugged.
Checking the wiring and connections to the control board
Hoover Washing... | Answered on Jan 10, 2019
Please see
https://www.espares.co.uk/advice/careandmaintenance/how-to-fix-an-e08-error-code-on-a-hoover-washing-machine
Where it says there is a problem with the motor speed sensor or sometimes with the motor itself
Hoover Washing... | Answered on Jan 09, 2019
(Obviously - you have to check the tap/faucet is turned on.)
Assuming this is not a new machine and has been running fine - the 1st thing to check is that there is no blockage in the water inlet pipe - sometimes a grain of sand/dirt gets into it and this can block it up - there is often a filter there which can be pulled out with a long nosed pair of pliers and sometimes there can be dirt under there.
If this does not help then there could be a problem with the electronic water inlet tap or with the water height sensor which could be blocked - leading the machine to think there is already enough water in the machine.
lastly there could be a problem with the electronic card which controls the machine.
source :https://www.espares.co.uk/advice/careandmaintenance/how-to-fix-an-e14-error-on-a-hoover-washer-dryer
Error code E14 relates to a water heating or control board fault.
  • Switch off and unplug your washer dryer.
  • Check the temperature sensor as well as the wiring to it.
  • Check the water heater element.
  • Check the connections to the control board and the board itself.
NEVER KNEW OF A NEED FOR THAT CHECK FOR BLOCKAGE TO THE PUMP
Hoover Washing... | Answered on Jan 03, 2019
take down make & model # contact manufacturer technician line, you may also turn your power on and off to wi-fi and retry to see if it works
Hoover Washing... | Answered on Dec 29, 2018
E08 is the motor speed sensor error code. Suggestion: Try a cycle with very few garments and see if it completes the cycle.
Hoover Washing... | Answered on Nov 27, 2018
Try unplugging for 5 minutes. That may reset electronics
Hoover Washing... | Answered on Nov 23, 2018
You will more than likely have to replace the dispenser box. Sone models u can pull it apart and run pipe cleaners through it
Hoover Washing... | Answered on Nov 10, 2018
Hoover Dynamic DYN8124D 8kg 1200rpm Washing Machine Logo
0 questions posted
Top Hoover Washing Machines Experts
shaun taylor
Hjalmer Lamminen
Hjalmer Lamminen
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Washing Machines
Most Popular Question
team hoover nextra 3166 like replace
  • Washing Machines
