My lexmark 3400series all -in -one, says the cover is open and
the power won't go off unless I un-plug it. I'v never had this happen
before when I changed the cartridge before. I know it is in place and
there is nothing blocking the cover from closing. It's like it is stuck
in this mode. I can't get it to do anything. Any suggestions.
Marty
The
problem could be due to a communication failure between one of the printheads
(cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps
below to identify and fix cartridge issues:
Please follow the steps below to identify and fix cartridge
issues:
Sometimes
the ink cartridge carrier won't automatically move to its loading position even
when the printer is on and the cover is open. Follow the steps below:
1.
Unplug the printer from the power source.
2.
With the cover open, hold the solid white strip that connects from the carrier
assembly to the ink cartridge carrier and gently slide the cartridge carrier to
the center of the printer.
3.
Remove the used cartridges.
4.
Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Sometimes
1.
2.
3.
4.
5.
I hope this information has been helpful.
Sometimes
1.
2.
3.
4.
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier
moves and stops at the loading position, unless the All-in-One is busy.
3. Remove your used cartridge.
4. Firmly insert your new cartridge.
5. Close the printer cover. Your printer will then ask you to align the cartridges.
Sometimes the ink
cartridge carrier won't automatically move to its loading position even when
the printer is on and the cover is open. Follow the steps below: 1. Unplug the
printer from the power source. 2. With the cover
open, hold the solid white strip that connects from the carrier assembly to the
ink cartridge carrier and gently slide the cartridge carrier to the center of
the printer. 3. Remove the
used cartridges. 4. Load the new
cartridges. Close the cover. 5. Plug the
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power source
to reset it.
6. When the printer turns on, reinsert one cartridge
first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge.
9. You can try to insert a different known working cartridge to determine if the other is faulty.
If cartridges are faulty, please contact Lexmark Technical Support Center for assistance and see if they can replace it for you. Please provide them a Proof of Purchase for both the cartridges.
Sometimes the ink
1. Unplug the
2. With the cover
the printer.
3. Remove the
used cartridges.
4. Load the new
Sometimes the ink cartridge carrier
won't automatically move to its loading position even when the printer is on
1. Unplug the printer from the power
source.
2. With the cover open, hold the
solid white strip that connects from the carrier assembly to the ink cartridge
carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close
the cover.
I have the same problem, I changed my cartridge and now my printer says "cover open". The cover is flat and the printer still does not work. Anybody found a solution.
Thanks.
gcross
printer says cover open after changing cart... but cover is closed perfectly.... PLEASE HELP
cover says open but its not
