Question about Lexmark JetPrinter Z55 InkJet
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to the power source.
Posted on Apr 18, 2011
May 02, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Just make sure you are using a genuine Lexmark cartridge and not some remanufactured, refilled or clone cartridges. Please follow the steps below to identify and fix cartridge
issues:
Jan 14, 2012 | Lexmark X4650 InkJet Printer
issues:
Jan 07, 2012 | Lexmark Z600 InkJet Printer
Your 2004 Libery has 2 fuse centers
1. Interior Fuses
The passenger fuse panel is on the left side of the instrument panel.
A label is attached to the fuse panel cover to identify each
fuse for ease of replacement.
2. Underhood Fuses (Power Distribution Center)
Your vehicle is equipped with an electrical power distribution
center located in the engine compartment near the
battery. This power center houses plug-in "Cartridge"
fuses which replace in-line fusible links. The power
center also contains "Mini" fuses and plug-in full and
micro ISO relays. A label inside the latching cover of the
center identifies each component for ease of replacement,
if necessary. "Cartridge" fuses and relays can be obtained
from your authorized dealer.
Oct 31, 2011 | 2004 Jeep Liberty
1.
Make sure the printer is on.
2.
Open the printer cover. The print cartridge carrier moves and stops at the
loading position, unless the All-in-One is busy.
Note: If
the carrier does not automatically move to the center, turn off the
printer/unplug the printer from the power source and then slide the carrier to
the center.
3.
Remove both cartridges from the carrier.
4.
Close the printer cover.
5.
Re-brick your printer. Pull out the power supply,
black box where the power cord is plugged in at the back of the printer, and
put it back after 30 seconds.
6.
When the printer turns on, reinsert one cartridge first.
7.
Close the printer cover and check for any errors.
8.
If no error appears, reinsert the other cartridge. Close the printer cover.
9.
Replace whichever cartridge is causing the error to appear with a new
cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 19, 2011 | Lexmark X7170 All-In-One InkJet Printer
1.
2.
Note: If
the center.
3.
Remove the color cartridge from the carrier.
4.
5.
6.
When the printer turns on, reinsert the color cartridge.
7.
8. If the error continues to appear, replace the cartridge with a new
cartridge or insert a different known working color cartridge to determine if it's a faulty cartridge issue.
Sep 19, 2011 | Lexmark X2650 All-In-One InkJet Printer
1.
2.
Note: If
the center.
3.
4.
5.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds).
6.
7.
8.
9.
cartridge.
Sep 11, 2011 | Lexmark X83 All-In-One InkJet Printer
Sep 07, 2010 | Office Equipment & Supplies
Mar 11, 2010 | Lexmark Z2320 InkJet Printer
Nov 11, 2009 | Canon i860 InkJet Photo Printer
Jan 08, 2010 | Lexmark JetPrinter Z55 InkJet
53 people viewed this question
