SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
time to replace the fuser assembly.
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
SOURCE: xerox 3100 mfp error code (HSYNC)
Its related to the LASER UNIT! When I had the problem I had the front cover off so it wasnt hitting the laser interlock switch which is located in the slot in the sheet metal on the front of the machine when the front cover is not shut........... If that makes any sense.
SOURCE: i own a Xerox Phaser 3100MFP and it keeps giving
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
