Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
?· Turn off the camera.
?· Remove the battery pack.
?· Press and hold the power button for 30 seconds.
?· Allow the camera to remain without power for 60 seconds.
?· Reinsert the battery pack.
?· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
I opened the camera case. The boards seem to be in good order, and the connectors properly connected. Any hints what to look for?
Thanks for the solution. Could you elaborate on it with some more details. I am not sure which one is the crystal oscillator on the mother board and how to heat it. Also, is it possible that this is related to the software lock Panasonic put in to prevent third part battery from being used? (I tried a third party battery). Thanks.
