20 Most Recent Panasonic Lumix DMC-FH1 / DMC-FS10 Digital Camera Questions & Answers
Put the media card in a card reader attached to your computer.
Panasonic Lumix... | Answered on Nov 17, 2016
There are recovery programs available. Google SDHC data recovery.
Panasonic Lumix... | Answered on Mar 04, 2015
Do you really want to connect your camera to your computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Panasonic Lumix... | Answered on Apr 29, 2014
Do you really want the Panasonic software when there are so many better alternatives available, such as Picasa (
http://picasa.google.com )?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
If you really want Photofunstudio then try http://l.go-for-files.com/j5GjQm7c6U1jxr5WZdbxM2bToSh0tbc4YrG5JnXulj53qNhhEuLPKFO2mjJDvMxaF%2BzHXxSUilYH18VbDdk5RAzZ
Panasonic Lumix... | Answered on Nov 17, 2013
You can try a new battery or make sure the older one is getting charged by the camera. Remember the camera needs to be in the "OFF" position when you try to charge it.
Panasonic Lumix... | Answered on Nov 11, 2013
I'd suggest going to this link for assistance with your camera if you are located in the US.
Click Here
Panasonic Lumix... | Answered on Oct 24, 2013
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as iPhoto.
Even if you have to purchase a card reader, you might save money anyway. The last card reader I bought cost me less than the last USB cord I bought (and I still haven't used that cord with any of my cameras, only with my tablet).
Panasonic Lumix... | Answered on Oct 21, 2012
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Panasonic Lumix... | Answered on Sep 23, 2012
First : is it the same to other SD Card?If yes thenSecond: is it happened to other SD Card?if the second answer is YES -> it might be the I/O part of the camera
but if the second answer is NO -> try to re format that SD Card it might contained a faulty fat (file alocation table)I hope it help
Panasonic Lumix... | Answered on Dec 29, 2011
Press Menu / Set button.
Choose the Settings Menu (Wrench Icon)
From there you should find the Lanugage Menu.
Panasonic Lumix... | Answered on Oct 22, 2011
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Panasonic Lumix... | Answered on Sep 21, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Panasonic Lumix... | Answered on Aug 15, 2011
Check out the Panasonic (Netherland) Website.
Hope it helps.
Panasonic Lumix... | Answered on May 22, 2011
if theres available online seller in your place try ordering online
Panasonic Lumix... | Answered on Apr 15, 2019
Tip
If you have a older Lumix that does not want to power on
As you know Panasonic issues Firmware Updates that can be downloaded online, and then installed using a computer and an SD card.
Some of those Firmware Updates made the cameras refuse to turn on if the battery was not an "approved" Panasonic battery.
This significant change was not publicly announced.
Panasonic Lumix batteries are available, but there are also dozens of different generic Lumix batteries available, and there is no reference source as to which generic batteries are "approved."
Therefore I would encourage you if you have a Lumix camera that is balking on startup to first try a genuine Panasonic Lumix battery that is fully charged.
You may find that the only problem was a generic battery that the camera did not care for.
(And of course many "Lumix" batteries sold online are not actually Lumix batteries, but merely counterfeits. They have Lumix markings and are often very good
imitations on visual inspection.)
Another reason some Lumix cameras will not power up is the memory card.
Sometimes people use a newer SDHC type card in an older Lumix, and the camera goes into electronic spasms trying to read the newer card. An older plain vanilla SD card will often solve the problem instantly.
If a Lumix camera is not powering up with a 8gb SDHC card there is a good chance it will power up immediately with a 1gb SD card.
I frequently recommend the Lumix TZ5 to people starting out, as it is a quality build, metal, not toy-like plastic, has more manual controls than most people will ever use, and the engineering is remarkable. I repair TZ cameras and donate them to homeless shelters and domestic abuse safe houses and college photography students and such, as they have full User Manuals available to download, full Service Manuals available for download in PDF format, have a very gentle learning curve, and produce photographs that are superior to many of the current cameras in the 600 to 800 dollar range. Yet a used TZ5 can be bought for 50 dollars or so.
Update the Firmware to v 1.2, never carry it in a leather camera case or pocket or purse or with any cloth of any kind, and you have a superb camera for many years.
on Aug 16, 2018 | Panasonic Lumix Cameras
Panasonic Lumix DMC-FH1 / DMC-FS10 Digital Camera Logo
44 questions posted
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
lost lead from camera computer 39 t
  • Cameras
