Fridge is running but not cooling, temp in freezer is 30 degrees and the fridge is at 59 degrees?? any suggestions?
Freezer coils will not defrost. Defrost thermostat is good.
Sounds like coolant is low in the system. Most fridges use a sealed system with refridgerant.
You may be able to have a sears guy or some other applicance house call repairman come and recharge it.
Also.. check that there is enough clearance around the fridge and that dust isn't clogging up the heat transfer pipes (that grid on the back.. or below the fridge) These guys need a lot of airflow to remove heat.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
