Question about GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC Side by Side Refrigerator
GE fridge/freezer on but no cold air
I have a GE refrigerator and fridge and freezer are on...you can hear it but the freezer is not cold...air is coming out but it isnt cold and food is starting to unthaw...model number is GSS22KGPAWW
Posted by pdsigep79 on
Anonymous
  • 619 Answers
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Posted on Mar 07, 2010
Anonymous
    New Friend:
We have a GEgss22 model. It seems to be running, but we have the temp maxed out and the fridge seems to be holding at 50 degrees. It is not cold enough.
Posted on Mar 29, 2010
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | GE Refrigerators
MY REFRIGERATOR MODEL#GSS20IETA BB DOES NOT GET COLD IN THE REFRIGEATOR SIDE . WHAT COULD THIS BE?
open the freezer and listen for the evaporator fan motor, if you can't hear it running then you need to replace it. it pushes the cold air from the freezer into the fridge to keep it cold.
Nov 13, 2009 | GE Refrigerators
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer stays cold and refrigerator side is warm
First check that nothing is blocking air circulation to the fridge from the freezer. Is the fan running ? You can usually hear it when you open the freezer. If not running , it needs replacing.
Jul 03, 2009 | GE PSC23NHN Side by Side Refrigerator
GE GSS25LGMF BB refrigerator freezing everything. Refrigerator is set on 1, still freezing.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | GE GSS25LGM Side by Side Refrigerator
GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC Side by Side Refrigerator Logo
692 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
