20 Most Recent Kenmore 18.2 cu. ft. Top Freezer Refrigerator w/Factory Installed Ice Maker Questions & Answers
Have you checked the GFI with some other appliance? Like a mixer. Sometimes the GFI are overly sensitive.
Kenmore 18.2 cu.... | Answered on Jul 15, 2015
In most older reefers, the fan in the back of the freezer does the entire job. It blows cold air through a duct that leads to the ******. If you have no cold air in the ******, but your freezer is still cold...but barely, your fan is shot.
Kenmore 18.2 cu.... | Answered on May 02, 2012
Sounds like the defrost circuit of your fridge has failed. If you remove the back panel of the freezer compartment, you will see the evap coil encased with ice. Normally the defrost circuit will turn off the compressor and turn on a heater to warm the coil to about 45 degrees to melt any frost build up. After about 40 minutes the compressor will kick back in to keep your fridge cool again.
The typical failures are that the defrost heater burns out. If you have an older fridge, the defrost timer fails to advance, causing the fridge to stay in cooling or defrost mode.
Kenmore 18.2 cu.... | Answered on May 27, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
etyhg
Kenmore 18.2 cu.... | Answered on Sep 29, 2010
On some refrigerators you must push in first to release the filter.
Kenmore... | Answered 2 days ago
Kenmore appliance model numbers have a three digit prefix (106 in this case) for the manufacturer. The rest of the model number indicates a lot of the specifics for the refrigerator. The third digit is the second group indicates the capacity. This fridge is a 22 cubic foot model (or slightly smaller).
I hope this helps.
Kenmore... | Answered on Jun 05, 2019
If your coils are froze up, this could be temperature sensor I believe or your defrost valve, usually back in the fridge is your coils if they are frozen solid you need to unplug refrigerator freezer let it thaw out, you will have lots of water so get towels and stuff to soak up your water once it is thawed,plug frigerator freezer back in give it time to cool back down if the refrigerator side is cool now then I would say defrost valve or temperature sensor will need replaced there also should be a fan that blows the cold air into your refrigerator,, was it run for about a day or so if it starts freezing up again that's more proof defrost valves not working
Kenmore... | Answered on Jun 04, 2019
Please post your model number for Kenmore product so we know what exactly we dealing with
Refrigerators Logo
10 questions posted
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
refrig sometimes trips gfi sometimes
  • Refrigerators
