The printer starting the print too close to the top of the page. Even when I print a "Print Quality Troubleshooting Procedure Guide" from the printers menu it is not centered in the page.
SOURCE: getting extra 1 inch margin on ''normal'' or ''best'' print
Hi - have you checked the settings for both the document(s) you are trying to print and the defaults for the printer? It could be that there is a default setting that is trying to override what you want to do. I can't think of a reason for it to act differently with different quality of print, unless the ink is running low - that can affect a document printing or not, but again, I would not think to this effect.
Some things to check on -
- Go to the control panel, open the Printers and Faxes folder, and right click on your printer.
Choose PROPERTIES. Make sure everything is set like you want it to be.
(If you are on a network of some kind, someone else's settings could be overriding yours. If you are not on a network, make sure "Do not share this printer" is checked on the sharing tab.)
-try to update the driver. Here is a good place to look -
http://preview.tinyurl.com/6bwuk8
I am assuming you have already actually checked for little scraplettes of paper that might be stuck near a sensor or an ink cartridge. I'd even pop the ink cartridges out and put them back in. Sometimes dust can build up on them if a printer isn't used often, or has been sitting for a long time.
Also, make sure you don't have a setting on your own computer to print out a blank sheet before a printing job. If your printer is actually run through an I/T department at work, they could have it set up by default to kick out a separator sheet to help keep orders separated.
I hope one of these things might work for you! : )
SOURCE: Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
You can now open and print the document in Word Viewer without receiving the error message.
You receive a warning dialog box about the unprintable regions.
SOURCE: HP business inkjet 1200 printer does not print footers
WOULD LIKE TO PRINT STUFF OF THE COMPUTER
SOURCE: HP LJ p3005 dn printer will not recogonize hp print cartridge.
you may use a non genuine toner cartridge, check another working cartridge
SOURCE: Printer is offline & will not print ... not even a test page.
First, make sure that the printer is properly connected to the computer and it's turned on.
Go to Control Panel > Printers > right-click the printer icon > select "Use printer Online".
Make sure the clear the pending documents on the queue before trying to print a test page.
Thank you for using FixYa!
