Whirlpool Duet GHW9150P Front Load Washer Logo
Anonymous Posted on Jul 04, 2011
I have a Whirlpool Duet Steam and the pannel is flashing F21, and the Door is Locked. I have held in both the Controls Locked/Unlocked and the PAUSE/CANCEL buttol but nothing is working. It is full of clothes and water
Anonymous
Level 3:
  • Master 5,081 Answers
  • Posted on Jul 04, 2011
Anonymous
Master
Level 3:
Answers
5081
Questions
Helped
2236794
Points
18738
Check this video for the how to resolve the F21 error
  • leerobyn Jul 15, 2011
    Thanks for this video. It worked great and my washer is back on the job. Thanks so much!
  • Anonymous Nov 17, 2012
    Exactly what I needed.
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Door locked with flashing red light on model W10578789
This might work try unplugging it for about 45 -60 seconds and see if it clears the problem. The red light is some type of warning and I would be safe in saying it is a safety device gone bad. Sorry I couldn't be of more help.
Col. Dana Gillespie
4helpful
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
My whirlpool duet steam washing machine has the error code F21 flashing on it and i was wanting to know what it meant and how to fix it
This means you unit is unable to drain the water out in a timely fashion, most likely you have a clogged filter in the pump causing this. Remove the access panel under the door, 2-3 screw at the bottom. The pump has a screw handle head on it the you can unscrew ad clean out the filter. Use caution, will contain water and once removed it will pour out, use a bucket to collect the water.
Stay dry...
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
6helpful
I think Ihave a wfw 9200, the door lock light is flashing and cannot be cancelled. There is a f21 fault code flashing. HOW can I open the door ?
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time.
As for the door locked issue, it is a by-product of the F21 error. Make sure you get the water out before attempting to open the door manually or it could be messy.
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about ¼" or until a click is heard.
6. The door may now be opened.
If you follow the link to my solution to this error you should be fixed up in no time.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance and leave a brief testimony.
Regards,
Macmarkus :)
1helpful
WhirlpoolGB AWO 3751 Door firmly shut but red door locked indicator starts to flash and programme will not start.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
3helpful
Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
1helpful
My control keys are locked
Showing ''cl'' on the front pannel.
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
