The amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Testimonial: "Really helpful and easy to understand reply. Thank you"
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,
I'm a bit lost on that
But If I read it correctly I connect the out on my EQ to the in on my cassette deck and then the in on my EQ to the out on my cassette deck.
Is that right and if so will the EQ also work on my CD deck (my CD deck isn't wired to the EQ yet)
Sorry to be so dumb and thank you for your replies and help
Liz
Hi Liz sorry it took me so long to get back to you , Ok,,I'm not sure what you have for inputs or outputs on your specific parts to this stereo , so lets try this again,, basically what you have that powers everything is the amp, so lets start there. and work with the EQ and the receiver, so,, first,, you need to go from the amp, to the eq, and back, this way anything that you ad after the fact will be patched through the EQ so everything works with that, So, Locate the Input and output from the amp,, add 2 RCA connections to that , red being right and white being left . you go out of the amp, to the in of the EQ,, and out of the EQ back into the In on the amp. This gives you sound that you can adjust with the EQ . now the receiver I assume is for stations mostly,, should have a spot by itself to the amp also? if not we can address that later. Be sure and do all of this with the units unplugged !!! ok so now we have that . Now, the cassette player,, yes you had that right,, in to out and out to in, so that completes the cassette , Now the CD player ( its just a player and not a recorder ) so you should just have one in to the amp from that , right and left. if you have a record player that should have a spot also,, just incase , so ya following me so far ? if this is ok,, or you need more info,, just let me know, I get a message received when you reply so I'll be sure and check back here ok. if the receiver needs to use the inputs on the amp and thats where the eq is at , lemme know as thats a pretty easy fix.
Thank you so much, I followed all of that and it works perfectly.
Thanks again
Liz
your very welcome , Please rate my reply
thanks for the rating Liz
Attached is a copy of the manual page showing the connections hope this helps
SOURCE: Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
SOURCE: Hooking up audio components
This was answered here: http://www.fixya.com/support/t1371668-having_hard_time_connecting_various
- OPTiC
http://www.djproaudio.com
http://www.repairny.com
SOURCE: how do I hook up
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
