20 Most Recent Technics SH-GE90 Home Equalizer Questions & Answers
3answers
1. The dislay flickers too
Bonjour, en cas de son perturb? en sortie du DSP, v?rifier et changer les transistors de mute Q11 et Q12 (2SC3327).
12/4/2022 3:15:39 PM • Technics SH-GE90... • Answered on Dec 04, 2022
The dislay flickers SH GE90.technics .it seems to
replace the 3 electrolytic capacitors in the power supply section near where the lead from the transformer connects to.
they're sat side by side.
you may notice only 1 might be leaky but replace all 3 for good measure.
i've had quite a few with exactly the same fault and all were cured by replacing the above.
hope this helps?
9/7/2019 10:23:21 AM • Technics SH-GE90... • Answered on Sep 07, 2019
I have technics reciever sa ax 6 (without tape
Click here.
3/31/2016 12:43:56 AM • Technics SH-GE90... • Answered on Mar 31, 2016
Hallo, all function works,but no signal and levels
detto :(
3/17/2014 7:16:02 AM • Technics SH-GE90... • Answered on Mar 17, 2014
Good day...My unit works 100%...i
The 2 larger power supply capacitors need replacing.These are prone to leaking on this particular model and causethe display to flicker.Depending on how bad the leakage, if you take the lid off youmay see evidence of this around where the power transformer leadplugs into the main PCB.
3/25/2013 10:00:17 PM • Technics SH-GE90... • Answered on Mar 25, 2013
Technics SH-GE90 DSP gives off high pitch sound, no display in the window,only the red dots down the side and the demo button dose not change demo modes.
Check power supply capacitors.These are prone to leakage on the SH-GE90 and can cause varioussymptoms such as no display or in some cases a flickering display.
3/25/2013 9:52:00 PM • Technics SH-GE90... • Answered on Mar 25, 2013
I bought SH-GE90 DSP And I pluged into 240V source
It is not possible for us to be able to determine the extent of the damage. It is possible that only the fuse has been damaged. It is also possible that the rectifiers have been dmaged. The bottom line here is that there needs to be some examination of the unit and some testing of the internal components. The best case will use parts in the $5 range. Worst case you are looking at $50 or more in parts. If the cost is not too high, take this to a servicer and ask for a detailed repair estimate.
Dan
12/19/2010 8:59:10 PM • Technics SH-GE90... • Answered on Dec 19, 2010
I will be upgrading my
If you use the amp for music most of the time I would certainly keep the older eq as I am assuming it is most likely a good quality analog device.
These modern ones are almost all digital and are not as nice or easy to use and probably introduce latency to the signal path. Sound is all about what you like and I would bet that you will prefer the older analog sound over the new digital version.
I am not sure exactly how this would affect the other uses of the new kit such as cinema etc.
Hope this helps Thanks for using FixYa.
8/17/2010 11:49:07 AM • Technics SH-GE90... • Answered on Aug 17, 2010
I have a Technics Stereo graphic equalizer. Trying
The power supply unit has failed in your equaliser. If it is the main transformer check for the continuity of the primary and if open you will need to replace with the same one or rewind with the same parameter.However if the thermal fuse is blown you can short the winding with a fuse wire. Also check on the dc side for any fusible resistors that would have opened out. Hope you check this out. Good day
8/11/2010 4:03:52 PM • Technics SH-GE90... • Answered on Aug 11, 2010
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
12/18/2008 5:21:13 AM • Technics SH-GE90... • Answered on Dec 18, 2008
USER MANUAL NEEDED
Hi - You can download the manual from the link underlined in blue below:
SH-GE90
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
8/29/2008 6:35:11 PM • Technics SH-GE90... • Answered on Aug 29, 2008
Technics RS-BX501 cassette deck door won't open
If you feel confident doing so, you could attempt to open the cassette deck and physically examine the gears to check for damage or debris that might be obstructing them. But do remember that there are risks involved when opening electronic equipment, especially if you're not used with doing this kind of work. If you're not sure you can do this securely, it would be preferable to get assistance from a qualified audio equipment repair specialist.
4/20/2024 10:23:23 AM • Technics Audio... • Answered on Apr 20, 2024
I have a Technics SU-V9 Stereo Integrated DC Amplifier and ACOUSTIC RESEARCH AR-328PS FLOOR SPEAKERS. I enjoyed for 6 months. Now amp goes into protection mode. What would cause this? Thanks
Could be one channel has failed in the amplifier caused by 40 year old components failing. Could be a shorted speaker lead, damaging the amplifier. Job to say without seeing it on the work bench with test gear.
3/17/2024 8:23:21 AM • Technics Audio... • Answered on Mar 17, 2024
Technics SH-GE90 Home Equalizer Logo
31 questions posted
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Technics Audio Players & Recorders
Most Popular Question
1 dislay flickers
  • Audio Players & Recorders
